4310 compact
/ 4310 compact #1
printolive
Nebraska
JD 4310 eHydro
I知 getting a reverse Potentiometer pedal code I have set the voltage on it exactly to spec ...still getting code - - 封
I ran continuity on wires they are good on the ohm meter getting a Tone ....and I found that
My online JD manual has the forward and rev wires at terminals switched at the harness plug at controller end, 686 and 687. I知 thinking potentiometers are new and set correctly wires are good could the controller be bad?
/ 4310 compact #2
/ 4310 compact
I make the breakout cable from the same link you posted
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
