4310 battery light on, but engine starts right up
   / 4310 battery light on, but engine starts right up #1
adegiulio
Red Hook NY
JD 4310
When I start my 4310, the battery light stays on, and the tachometer doesn't work, but everything else works just fine (lights, blinkers). The engine cranks like it has a full charge. Any thoughts?
   / 4310 battery light on, but engine starts right up #2
Sounds like an alternator failure, or the wiring between it and the
instrument cluster.
On my 4300, the tach and alternator use the same wiring.
Your tractor will continue to start until the battery is run down.
Ah yes...once again I forget that diesels run on compression and don't need electricity to spark each cylinder.
   / 4310 battery light on, but engine starts right up #4
But you DO need the electrical system working to operate your
fuel cutoff solenoid, and various parts of the HST, PTO, etc. That
is why your symptoms point more toward the specific alternator-
related failure.
Yeah, the alternator belt was chewed up and came off. I'm actually pretty embarrassed that I asked such a lazy question. Thanks for the responses...
   / 4310 battery light on, but engine starts right up #6
Always glad to hear about the easy/cheap fixes. A belt is much better than an alternator.
JB
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
Informational Lot - Financing (A55218)
Informational Lot...
9202 (A50322)
9202 (A50322)
