4310 50hr service
/ 4310 50hr service #1
JimmyD
VA
JD4310/Sync Shift/ 430 loader /toothbar
Just finished the 50 hr service on my tractor. It wasn't as bad as I thought. As expected the suction side filter was on there really tight. Hydraulics took about a half a gallon more than the book says is the approximate fill. I also replaced the instrument panel glass that was fogging up and that was a stinker to finish. Getting the U shaped tilt gizmo on the steering column back on correctly took forever. I'm wondering if the technical manual has a procedure for this. I dread having to pull the cluster again to replace a lamp. etc,,,
/ 4310 50hr service #2
</font><font color="blue" class="small">( I also replaced the instrument panel glass that was fogging up and that was a stinker to finish. Getting the U shaped tilt gizmo on the steering column back on correctly took forever. I'm wondering if the technical manual has a procedure for this. I dread having to pull the cluster again to replace a lamp. etc,,, )</font>
Actually you went from the wrong side You are supposed to remove the engine!! /forums/images/graemlins/tongue.gif
2007 Generac Quiet Source Generator (A61572)
2007 Generac Quiet...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
(2) 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) 15-19.5 TIRES...
CASE IH 290 AFS MAGNUM TRACTOR (A64280)
CASE IH 290 AFS...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
