4310 50hr service
/ 4310 50hr service #1
JimmyD
Bronze Member
VA
JD4310/Sync Shift/ 430 loader /toothbar
Just finished the 50 hr service on my tractor. It wasn't as bad as I thought. As expected the suction side filter was on there really tight. Hydraulics took about a half a gallon more than the book says is the approximate fill. I also replaced the instrument panel glass that was fogging up and that was a stinker to finish. Getting the U shaped tilt gizmo on the steering column back on correctly took forever. I'm wondering if the technical manual has a procedure for this. I dread having to pull the cluster again to replace a lamp. etc,,,
/ 4310 50hr service #2
</font><font color="blue" class="small">( I also replaced the instrument panel glass that was fogging up and that was a stinker to finish. Getting the U shaped tilt gizmo on the steering column back on correctly took forever. I'm wondering if the technical manual has a procedure for this. I dread having to pull the cluster again to replace a lamp. etc,,, )</font>
Actually you went from the wrong side You are supposed to remove the engine!! /forums/images/graemlins/tongue.gif
