431 brake adjustment
   / 431 brake adjustment #1
araz33
Just acquired a 431 that was a bit neglected. Brakes were almost bottomed out the first time I used it. Tried to adjust but the star adjustment is frozen. Any ideas on how to break free without removing the tires and breaking it free. Should I just try and adjust with the turnbuckles and forget about it?
   / 431 brake adjustment #2
You will need to remove the brake drums to inspect the brakes. If the star wheels are frozen, which is uncommon, you will need to free tham. Removal of the wheels/tires and brake drums is not difficult.
Are you using a proper brake adjusting tool?
SDT
using a screwdriver- will any break adjustment tool work? is there one specific to 431?
   / 431 brake adjustment #4
Any automotive brake adjustment tool will work. Though probably possible, it will be more difficult with a screwdriver.
SDT
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
