4300
darrenjttu
Glen Rose, Tx
JD 4300
I have been using my 4300 a lot lately and the motor has turned off and I cant figure out why. It only happens when I have been using it for a while and then when I go over a big bump or rock the engine dies. Some times I can restart it right away but most of the time I have to wait around five minutes. I cant figure it out. I check all the wires and looked for a loose connection but every thing it tight. I initially thought electrical or seat safety button but those have all checked out fine. Any thoughts?
Fuel shutoff solenoid/thermistor?
/ 4300
Can the safety switch under the seats go bad? I suspect it might not be working wright. Can I bypass it to see?
Just put a jumper wire in the connector. Easy to do, and the way I have run mine for 16 years.
/ 4300 #7
Its there a way I can test the fuel shut off solenoid/thermistor?
Be careful working on the shut off. The coil in it runs at about 6 volt but pulls in at 12 volt. The thermister reduces the voltage. If you do not reduce the voltage you will find smoke escaping from the valve and its a SOB of a job to get it back in.....
/ 4300
I zip tied the seat safety switch today and ran tractor hard for 3 hours moving rocks. It didn't shut down once. I hope that was the problem.
I had that same symptom once. It turned out to be a loose battery connection. I thought it was the seat safety switch
Lynn
2023 Deere 333G (A64911)
2023 Deere 333G...
PORTA POTTY (A68842)
3pt Ditcher (A64912)
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2014 JCB 190T SKID STEER (A65056)
2014 JCB 190T SKID...
