4300 won't start
   / 4300 won't start #11
It wasnt used on the ten series. they changed to better system.:cool:
   / 4300 won't start
PROBLEM SOLVED!
Thanks to everyone for the assistance.
I pulled the solenoid and it did not work. I was going to pull the connector from the harness to test the wiring and could not get it off, so I then was going to poke the probe thru the sheath to test it. Before starting that I turned the key and CLACK! now it works...
Must be possessed by electrical gremlins. I once parked it next to an English car, probably caught a little bit of Lucas disease.
   / 4300 won't start #13
This is just a message to say thanks to those of you that posted since I had similar woes w/ my 4300. This is I would not have figured out by myself and the parts guys at JD didn't know about this either. I was surprised the fuel shut off solenoid would show it was getting power with a problem before the solenoid in the circuit and I would have ended up paying $140 for a new solenoid for no reason.
I wasn't hearing the click that I normally did after turning the key before hitting the starter. After looking here I started with the most economical fix, the thermister. The trouble was I did not have any butt connectors on hand to tie in the thermister so tried using electrical tape as a quick fix, obviously it did not work.
The test light showed the solenoid getting power so I assumed it was a bad fuel shut off solenoid. I took it off, she fired up. After folling instructions from another thread I ended up pushing in the piston on the solenoid squirting oil out the hole and cleaning it off and I then put the solenoid back on to make sure that wasn't the fix. It was a no go. I took the solenoid back off and checked the resistance, 25 ohms so it should be working. I then addressed my sloppy thermistor replacement which was a royal pain in the arse, put the solenoid back in place and we've been in business since.
Thanks for all the help, evidentially this has been a problem for quite a few people but neither JD parts guys were steering me in the right direction before checking here.
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
