4300 rear 3-pt issues
/ 4300 rear 3-pt issues #1
Fly5150
Racine, WI
Deere 4300
I have a new to me 4300 that has an issue with the rear hydraulics. When I adjust the lever for lifting the 3-point, it will not respond until the lever is almost all the way up. Then it will raise up till it hits top, and then the engine bogs, until I slightly lover the lever. It will hold in a position, if I put the lever in just the right location.
In my searching so far it looks like either something in the RockShaft valve assembly, or adjustment issues with the linkage. Or both.
Any good suggestions on parts to just order, and then where to start when I tear into it?
Thanks
Dave
/ 4300 rear 3-pt issues #2
Thanks you for that link, Looks like I know exactly what I'm tearing into this weekend. I think the hardest part will be the adjustment of the arms to get everything moving smoothly again. Im thinking the tech manual will be a purchase today...
-Dave
/ 4300 rear 3-pt issues #4
Dave
Here is the component location from the tech manual. Item #8 is the feedback arm.
Shout back if you have additional questions..
so far I found one drift pin that was sheared off. Running to the store this afternoon and will see how it works once I get that fixed. Thanks!
Had to remove the cotter pin to get the linkage to move so I could one up the holes. Hardest part of the job was getting clearance for the drift to hammer the new pin in!
Fixed the problem, and a slight adjustment on the linkage so it doesn't overload at full lift. All fixed up! thanks for the help!
/ 4300 rear 3-pt issues #8
Great to hear.. I recall having to replace a sheared pin in the PTO control lever.. similar tight location to drive out the old and in the new...
/ 4300 rear 3-pt issues #9
hi neighbor from mchenry il. the reason those pins break is linkage seazes up lube everything with a good penetrating oil and exercise it back and forth you will see it loosens up
/ 4300 rear 3-pt issues #10
I have the same issue, having a hard time getting the shaft to free up and move, any recommendations or tricks, ? I would hate to put it all back and have the pin shear again,
/ 4300 rear 3-pt issues #11
penetrating oil where the linkage shaft goes thru any bushings and work back and forth be patient takes a while but you will know when its freed up big difference
/ 4300 rear 3-pt issues #12
Thanks I will keep working it,
/ 4300 rear 3-pt issues #13
aluminum case with steel shafting is what is causing the problems. I had these issues on 3 pt feedback and the brakes on both sides. It was a constant battle that only ended when the tractor was no longer in my possession. I had a 4300 for 10ish years. It was a great tractor for it's size but there were small things that just drove me nuts with it.
/ 4300 rear 3-pt issues #14
No problem with the 4300 in 23 years, with the 3pt lift system.
2002 Pace American of Texas T/A 26FT Enclosed Trailer (A61573)
2002 Pace American...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
Caterpillar 3408/3412 Industrial Engine Service Manuals (A63117)
Caterpillar...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
