4300 PTO stalls
   / 4300 PTO stalls #11
Oh, yeah, you can also drain your oil, pull the suction screen, and look
into the sump to see if there are any clutch chunks in there. Good luck,
Jeff.
   / 4300 PTO stalls #12
Are you sure you are pushing the PTO lever all the way forward, not stopping at the first notch? Hard for me to imagine with 1000 hours your clutch is worn out. The 4300 (like my 4400) is mechanically engaged, on more than one occasion I did not push it "all" the way forward, and it will act like it is slipping.
Wayne
   / 4300 PTO stalls
Wayne
No, I'm not sure. I will check into that. I just thought if it was turning it must must be fully engauged. Thanks for the reply I would feel pretty stupid if I tore into it and it could of been something so simple.
Jeff
   / 4300 PTO stalls
Wayne_H I think you may have hit the nail on the head. I say may because I dont want to jinx myself. Today I was using the auger and put the lever as normal and it would stall on a big hit. Then I engauged it even further and went right back in the same spot and it wouldnt stall( Knock on wood). I really appreciate the help from all of you.
Jeff
   / 4300 PTO stalls
I havent used it sence the other day when I reported that it seemed to work right when I engauged it all the way. At least I some pretty good hope now. I'll probably be back on it this weekend and I'll let you know.
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A55788)
2018 Nissan Titan...
