4300 PTO stalls
   / 4300 PTO stalls #1
jeff408
Randle WA
JD 4300
I first noticed it when I was running the rotary tiller, it would stop the tiller when it would hit a rock or something. Then when I was using the posthole digger today the auger would stop if I hit a rock so I would pull it up and it would start turning again. Any thoughts.
Thanks, Jeff
   / 4300 PTO stalls #2
Possibly the PTO clutch is slipping...how many hours on the machine?
   / 4300 PTO stalls
1000 hrs. Thats kind of what I was thinking, clutch slipping. If so how big of of job is it to fix? Also can I harm anything if I continue to run I that way. Because it seems to work just fine tell I hit an immoveable object.
   / 4300 PTO stalls #4
User dfkrug may be able to help you, he is in the process of rebuilding a 4300 as we speak and knows the insides pretty well. View the thread HERE.
   / 4300 PTO stalls
Perfect, that helps a lot.
   / 4300 PTO stalls #7
Unfortunately, I was wrong about the 4310 vs the 4300 PTO clutch.
The former is electrically actuated, so it can be removed and fixed
thru the rear PTO cover. On the 4300, you have to remove it and
the 3-pt cylinder (rockshaft) housing. At least you do not have to
crack the tractor in sections.
This PTO clutch problem seems to be pandemic with the 4x00s.
   / 4300 PTO stalls
Is the PTO clutch something your average backyard mechanic can tackle? Can the clutch plates be replaced or do you have to buy a whole new clutch?
   / 4300 PTO stalls #9
Getting at the clutch is not bad at all. You do need to lift off the 3-pt
cyl housing, which weighs 80-90#, and is clumsy. Also, the right rear
wheel needs to come off so you can get the PTO shift shaft out. No
special tools required.
First thing I would do is remove the rear gearbox case cover (PTO cover)
and see what you have in the sump. Like clutch chunks.
As for parts, JD sells the clutch pack (9 friction discs and 8 plates) for
$240, which is high, IMO. I returned my pack after I was able to locate one
more separate friction disc---used but OK. I have one extra if that is
all you need. I found that there was enough play in the clutch engagement
to cause the last disc in the stack to slightly protrude from the clutch
basket, which caused that disc to break. My solution was to eliminate one
friction disc, replacing it with one clutch plate to get the right overall
thickness. My PTO clutch now has only 8 friction discs, but it seems to
work in my dry tests.
Did you look at the photos I posted?
   / 4300 PTO stalls
I read through your 4300 rebuild with great interest before I knew I needed to do some PTO clutch work. I need to go back through and see what more I can learn. I realy appreciate you and the others on here who are willing to help out those of us that need help.
Thanks, Jeff
Hyster H225E (A47384)
Year: 2006 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: Plate: Body Type: 3 Door Van; (A51692)
Year: 2006 Make...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
