4300 Loader Problem
/ 4300 Loader Problem #1
yooperdave
Veteran Member
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
My Uncle has a newer JD 4300 HST with a front end loader.
The tractor works well except for the loader.
The loader does not "stay up" when loaded. Is there a valve or something that I can adjust?
Yooper Dave
/ 4300 Loader Problem #2
</font><font color="blue" class="small">( The loader does not "stay up" when loaded. Is there a valve or something that I can adjust? )</font>
Here is a link to the Deere technical page that deals with this issue. John Deere Tips & Troubleshooting They give some details as to how to determine if the problem is in the SCV or the cylinders.
I suspect that your uncle will need to rebuild the boom cylinders. I have had to rebuild all four cylinders on my 430 loader as have several other folks here on the forum.
/ 4300 Loader Problem #3
Jim,
Thank you for the information...I have a nearly new 4210 with a 420 FEL and have been leaving the bucket at full height with the tractor engine off while working on my roof. I was concerned about the settling but according to the link you provided my JD is within normal range.
/ 4300 Loader Problem #5
</font><font color="blue" class="small">( How many hours on the loader when you had to rebuild the cylinders ? )</font>
No where near enough that I should have had to do it. The tractor and loader were bought new in September of 2000. I rebuilt the curl cylinders in May 2003 and the boom cylinders shortly after. I imagine that the tractor had about 650 hours at the time.
The problem is that an o-ring installed under the piston ring to tension the piston ring against the cylinder wall failed.
Deere supplied an o-ring made of a different material in the rebuild kit. Fortunately, the parts only cost about $15 per cylinder and the process is pretty straightforward, once you figure out how the cylinder comes apart.
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
