430 with stuck brakes
   / 430 with stuck brakes #1
jbradley
Clarinda, Iowa
JD 4020, JD 430 garden tractor, BCS 948, BCS 732
My wife was using my 430 and slammed on the brakes, which resulted in the brakes jamming. The throddle will not move forward at all, but will move slightly in reverse. The parking brake lock is in the unlocked position, but will not move, either. Where might the jam be located? I'd just as soon not have to take the seat and fenders off if at all possible.
Thank you.
   / 430 with stuck brakes #2
When I bought my first jd 420 it did that too. The park brake release rod bends if you don't push the brakes in when you release them. If you press the brakes hard and pull up on the release hand they should release
That was indeed what the problem was, though I initially couldn't get the parking brake to release. I had also forgotten which was the drive position of the parking brake and which was the brake position. It wasn't until I had the fenders off, and the side panel door off, and the floor pan off, that I found that it was the parking brake latch. After prying it up, everything works fine.
Since I now have everything exposed, I'm going to give it a power washing before putting it back together.
   / 430 with stuck brakes #4
Always good to find an easy fix, and have all exposed for a good cleaning.
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
