Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,088
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Bought this 430 several years ago. Been working fine. Couple years ago the forward reverse lever "slowed down" Meaning, instead of going to 100% forward and 100% reverse, it might only go to 70% forward and 40% reverse. Like it's motion has narrowed.
Have chassis off now (mower still on underneith if that matters)
This did this several years ago. Vague memory says I then also, had the chassis off and wiggled or tightened or something, an item down that tunnel.
Today, all looks well. I've not taken the 'knob' off the transmission nor done anything else. I thought I might ask first to see if someone has an idea (is it an external adjustment, might I have a bunch of crud inside the transmission and it's shot in those outer ranges, something other)
Appreciate any thoughts. I only have weekends to do this type stuff and that's if it's not raining!!
. The manual calls for them to be recessed 3mm in. First one I think was close and put the housing back on, tightened middle bolt evenly both sides. But when I installed the other side( I set seal into hole, then used a 2x4 to get it flush) I then was setting with seal driver , and it went too far
][emoji6
][emoji[emoji6
]" data-source="post: 0"
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
