430/460 Loader specs
/ 430/460 Loader specs #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I have been able to locate most specs for these loaders at the Deere site. Does anyone know the digging depth?
I usually fire off questions, without searching first, but I have looked everywhere; its probably right in front of me...
/ 430/460 Loader specs #2
Mike
The digging depth for a 430 loader on a JD 4300 is approx.
6" depending on tire size.
KGO
/ 430/460 Loader specs #3
I posted this before, but here it is again. This is the full spec sheet for the 460 loader. It shows a digging depth of 6" also.
And I am SURE I saw it, but for the life of me I couldn't find it again... I don't get much success with TBN's search, I guess google has me spoiled./w3tcompact/icons/grin.gif
THANKS FOR THE RESPONSES, YA'ALL!
I see you have the 430, but the sheet you posted is the 460, are the specs very differant?
How do you like your setup?
/ 430/460 Loader specs #6
The owners manual covers both the 430 and 460 loaders. I don't have a spec sheet for the 430 here right now, but here are the specs that I found for the 430 on the JD configurator:
430 Loader (For 990, 4300-4400 and 4310-4410 Tractors)
61" (1550 mm) Materials Bucket
Quik-Tatch Parking
Quik-Change Attachment
Mounting Frame
Hood Guard
Specifications Meet ASAES301.3
Specifications for 4300-4400
and 4310-4410 Tractors:
Lift Capacity - 1258 Lbs.
(572 kg)
Breakout @ Pivot - 3299 Lbs.
(14676N)
Lift Height - 101.4" (2575 mm)
Rollback Angle - 30 Degrees
Dump Angle - 45 Degrees
Specifications for 990 Tractor:
Lift Capacity - 1102 Lbs.
(500 kg)
Breakout @ Pivot - 3285 Lbs.
(14610N)
Lift Height - 101.9"
(2585 mm)
I love the 430 loader on my tractor. I keep finding more uses for it all the time. Best self propelled wheelbarrow I ever had./w3tcompact/icons/smile.gif
/ 430/460 Loader specs #7
I really like my 4 in 1....loader...its the ultimate.
