425 w.1430 wheelmotor boxes and 28.3ci wheel motors
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Finally had an opportunity to snap a couple pics of my 425 in use, after upgrading the wheel motors. Here's a couple pics of its stance with 26x12x12 Deestone lug tires and the larger Surplus Center wheelmotors that come with brake drums/hubs:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #2
Nice! :thumbsup:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #3
Good gravy that's a wide standing mountain beast!!! :laughing:
Any problems with the front and back tires hitting each other at full turns?
No, they don't hit. But, they're about 12" apart when fully articulated...
And it works well on these slopes:
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #5
Nice.
That would solve two problems that I have notice: insufficient clearance between wheels and frame for tire chains, and weeds getting choked up between wheel and body when brush hogging. At least a couple of inches more clearance would be nice.
Did you have to replace the hydraulic hoses?
No, just pulled the existing hoses out a bit. Did require buying adapters for the fittings, though...
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #7
Did you hook up the breaks? My tractor's 11years old and I think those pin breaks have been frozen for 10.
No pin brakes. I'm trying to find used backing plates for cable-operated drum brakes. I understand EzGo may have used them on golf carts in the 1980s or so that are the same size -- 5.25 in (625mm).
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #9
Nice. Looks like a real beast.
   / 425 w.1430 wheelmotor boxes and 28.3ci wheel motors #10
12" between tires at full turn is mor than I have now. Nice!
What's the width outside to outside now?
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
