4230 Hydraulics Stopped Working
   / 4230 Hydraulics Stopped Working #1
apewrangler
Vicksburg, MS
Got a 4230 with a front loader. Worked all day Friday hauling dirt in the loader with no issues. On Saturday, the U-shaped hose between the hydraulic pump and cooler blew out. We just cut the end off, put it back on, and topped of the fluid. Ran the rest of the day with no problems.
Yesterday, my dad was using it to scoop up some grass. He backed up some and changed gear to go back forward and all the hydraulics quit working - front loader, three point hitch, steering and transmission. There was no leakage from anywhere and no out-of-the-ordinary sounds.
The pump turns freely and makes a gulp-like sound as if the shaft is still in tact. There's just no fluid going to or from the pump. With the tractor running, there just doesn't appear to be any pressure in the system.
Any help is greatly appreciated.
Andy
   / 4230 Hydraulics Stopped Working #2
Did you check the frt hyd pump coupler is see that it's not stripped??? Next if it has a Quad-Range or Syncro-Range trans remove 3pt center link attaching bracket and plug under the bracket. Pull trans hyd pump drive shaft and look for rounded off corners on the hex shaft. How long since trans filter was changed and sump screen cleaned.
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
