422 vaporlock
/ 422 vaporlock #21
Sometimes when I have been working the machine very hard, I will let it run at 1/4 to 1/3 throttle for several minutes while the cooler fan is running just to bring the temps down a bit before shutting off the unitl. I use the old fashioned way of sticking my hand over the cooler fan and feeling the airflow. You can tell the difference very well with your skin. Mowing seems to be the hardest chore as the thing is running full blast with quite a load. Some day I will put a thermometer in the outflow of the fan to see what the temps are.
/ 422 vaporlock
I've tried that, MR, with little success. Maybe I didn't let it run long enough. I haven't tried that since tying the fuel hose back away from being in contact with the hydraulic hoses tho. Heck, maybe there isn't even a problem anymore since doing that. I hope to give it a test Saturday. I still plan on trying JJ's suggestion of running the fuel hose through a larger hose, which I'm sure I can find laying around in the garage. At the same time I'll check for silicone at the tank outlet, per BobRips. I'd like to get that deep loop out of the line, too, on the suggestion of NJBill.
Doing all of those things at the same time shouldn't take very long.... if it's nice weather (as it is supposed to be) I won't want to spend my time working ON the PT as much as working WITH the PT. Thanks for all the great ideas!!
Phil
/ 422 vaporlock #24
<font color="blueclass=small"> "" higher octane fuel, doesn't it make the engine run hotter ""
No, only if the engine thereby produces more power. Higher octane fuel allows higher compression and/or more ignition timing advance to be used to produce more power, without causing detonation (knocking). If the octane rating of a particular fuel is high enough to prevent detonation in a particular engine, there is no advantage to using a higher octane fuel. Modern computer controlled auto engines with knock sensors will ****** or advance the ignition timing to compensate for the octane rating of the fuel being used, and thereby prevent knock while producing the maximum power that that fuel will allow. The small gas engines used by Power Trac are not that sophisticated, and only require the minimum octane rating as specified by the manufacturer. Some premium fuels may contain a better additive package which may help keep an engine cleaner, for example, or make it less subject to vapor lock, but most likely do not justify the added expense of using them in small engines.
BTW, if you don’t know what this octane business is all about, let me give you a few hints.
When petroleum was first distilled into its components, it was discovered that by mixing the distillate octane with the distillate heptane a nice fuel called gasoline could be produced. They soon learned that gasoline that had higher levels of octane in it burned more smoothly without exploding (knocking) at the higher combustion chamber temperatures produced when higher compression or more ignition advance was producing more power.
Now they use other additives to make the blend perform like it had a given level of octane in it. Therefore, a modern gasoline that has an ‘octane rating’ of 89, for example, performs like an old 89% octane/11% heptane gasoline. So a gasoline with a octane rating of 106 would perform 6% better than pure octane!
Diesel fuel burns so slowly that it will burn, not explode, even though the compression ratio in a diesel engine is 2~3 times as high as in a gas engine. That is also why diesel engines must operate at very slow to moderate RPM.
/ 422 vaporlock #25
<font color="blue"> When petroleum was first distilled into its components, it was discovered that by mixing the distillate octane with the distillate heptane a nice fuel called gasoline could be produced </font>
Yeah, I startarted reading about that a couple of days ago when I was looking up some information on gasoline and octane. I've never had to run higher octane gas in anything, although I chose to do so in my motorcycle many years ago. I've rarley had any engine knock. Maybe a little back in the late '70s with an old Chevy 230 straight 6. I recall just shifting into a different gear to change the RPMs and it went away. I also recall a little run-on back then. After we re-built the engine with different cam, carb and distributor, it was gone completely. That stock engine was a little workhorse, though. Went 150,000+ before we rebuilt it and probably went another 50,000+ until the body rotted off the car. And I abused the heck out of it. Chevy straight 6's seem to last forever.
Anyhow, thanks for the info on the octane to everyone.
/ 422 vaporlock
DANG!!
I wish we all lived closer to each other. There are so many members here that I'd like to meet [and share some beers] in person. This thread illustrates the reasons "why". If ANY of you get anywhere near northern California and don't offer to stop by, I'll learn how to flame your butt so bad to where you can't sit down for a week.
Phil
/ 422 vaporlock #27
<font color="blue"> Chevy straight 6's seem to last forever. </font>
So true.
My first car was a 1953 Chevy 2dr HT. Paid $100. Later I found out that the engine had been replaced with a '54 model. The only real problem was a persistant oil leak. It's a little hazy now, but I think it was the rear seal.
Anyway, I was short on cash, so I couldn't afford to repair it or keep the oil topped off. I used to drive it until it ran low on oil, which was announced by that most insistent of all annunciators, the rod knock.
I would shut it off, wait about five minutes to allow the oil to drain back into the pan, and then start it and quickly but gently drive to the nearest gas station, where I would buy a quart of oil, and if I was splurging, maybe a buck's worth of gas.
Ahhh, the blithe ignorance of youth.
/ 422 vaporlock #28
One more note on fuel grade and vapor lock -
About 10 years ago, when I was still working as an auto mechanic, I attended a number of advanced driveability diagnosis seminars. The instructors frequently told us that higher octane fuel might actually make vapor lock worse, as some of the anti-knock and cleaning additives actually increased the volatility of the fuel.
The bottom line was that fuel formulations are changed frequently, and that we can't simply rely on higher octane to make our engines run better.
If I get vapor lock problems on my 425, I'm going to start with insulating my fuel lines...
Gravy
/ 422 vaporlock #29
Hi Phils,
I was away from the Forum for the past week--on Spring break, travelling w/ family in CA. We went up to Mariposa to see our land, and then hopped over to Yosemite. Our son took his first ski lesson at Badger Pass which has a 10 foot base, and was snowing to beat the band while we were there.
On the vapor lock problem, I too experienced this last Summer, and had a great discussion w/ <font color="red"> pairodime </font> about it. I also had the problem w/ detonation at shutdown.
I used our race car pyrometer and measured the air temperatures adjacent to where the OEM fuel filter was located (just inboard and below the muffler). Temps were in the 300 degree + range. Gasoline boils-off completely at 260. No wonder there was a problem! You don't have to be above the boiling point of gasoline to have vapor lock, but being above it will guarantee the problem. I have changed over to thick black SAE rated fuel-vapor hose, 1/4" ID (~$1/ft at Auto Zone), and replaced the fuel filter. My OEM filter had an outlet of 0.18" ID, and the new one, a generic off the shelf unit has outlet of 0.25" ID. I also relocated the filter to be forward of the black steel barrier between the engine and battery.
I also wrapped the exhaust manifold with racers exhaust header wrap made by DEI Products I stopped the wrap just before the manifold connects with the muffler. Unlike pairodime, I have experienced absolutely no sag nor warp anywhere in the exhaust system.
I also applied DEI's hj-temp adhesive "Floor & Tunnel Shield" (look under heat shield area of products) to the entire engine side of the black steel barrier located just aft of the battery. What a difference that made. Everything forward of that barrier is now cool enough to touch immediately after shutdown. The battery is no longer too hot to touch, and the gas tank is cool as well.
I also sheathed the entire fuel line and fuel filter with a DEI heat sheath w/ velcro closure. We use these in our race cars, and they are also used a lot in aircraft where vapor lock might be more of a problem than for us. It comes in a 3 foot length which is more than enough for our units. DEI doesn't sell direct, but you can get their products from Summit Racing where it is discounted from the MSRP.
I conveyed all this to Terry at PT. He was initially surprised about the temperatures, and indicated that he would talk to staff about going back to the thick black SAE rated gas-vapor fuel line. The clear plastic Tygon tubing was never intended for this harsh a service application. Mine was clear Tygon. Pequeajim's was the yellow fuel rated Tygon. Before I replaced it, mine sagged at least a foot into the bottom of the tub!
In our machines, the fuel pump is downstream of the tank, and it is sucking fuel to supply to the engine. The fuller the tank, the higher the pressure head at the pump (vapor and/or liquid), and the easier it is for the pump to deal with entrained gas vapor. Reason we don't see vapor lock in modern cars is that the pump is upstream, in the tank itself, so the fuel is being pushed from an area with fuel at a lower temperature directly to the carb or the injectors.
BTW, while I replaced the fuel line and filter, I also installed a dripless"quick disconnect" in the line upstream of the filter, between the filter and tank. That way, I can remove the tank easily and w/o losing gas from either end.
On the matter of detonation, I use 91-93 octane gas, as was recommended to pairodime by Jack Robin. He also recommended, and I am using the lead substitute which is found at Wally World. Terry at PT confirms this, too. Terry recommended shutting down directly from 1/2 throttle, i.e., do not bring the engine down to lowest idle and then shut down. I didn't believe it until I tried it. Since I started doing shutdown from 1/3-1/2 throttle, I rarely have the detonation problem.
Hope this helps Phils. If you need any specifics on product numbers, etc, drop me a PM...
/ 422 vaporlock #30
</font><font color="blue" class="small">( I wish we all lived closer to each other. There are so many members here that I'd like to meet [and share some beers] in person. )</font>
TractorByNet.com is better!! You can chat with folks from all over, they don't drink your beer, and if they do get drunk and unruly, you can kick them out with just a click of your mouse!!!! /forums/images/graemlins/cool.gif
PS: I do NOT wish to offend or dishearten any PT-425 owners with Robin engines, so I will NOT report that my PT-425, built 2/4 with a Kohler engine, came with thick black 1/4" ID SAE rated fuel-vapor hose , and a 1/4" fuel filter, and that they are not located near the exhaust, and that I have not had a bit of vapor lock even while stump grinding under the hot NC sun last August!!
/ 422 vaporlock #32
i don't think the engine mfg. has anything to do with the poor routing of a fuel line.i never had a vapor lock problem, the only fuel issue was the garbage they dumped in at the factory.i had to take the carb. apart and clean it out.i'm sooooo glad i didn't have to pay $3500 more to get a kohler /forums/images/graemlins/cool.gif
/ 422 vaporlock #33
</font><font color="blue" class="small">( i don't think the engine mfg. has anything to do with the poor routing of a fuel line.i never had a vapor lock problem, the only fuel issue was the garbage they dumped in at the factory.i had to take the carb. apart and clean it out.i'm sooooo glad i didn't have to pay $3500 more to get a kohler /forums/images/graemlins/cool.gif )</font>
The change of engine resulted in a redesign of the engine compartment which produced problems not previously encountered.
My steel gas tank also shed a considerable amount of garbage, but it was removed most effectively by the 1/4" clear fuel filter BEFORE it could reach the Kohler carb! After 200 hours I simply spent a few minutes installing a fresh filter. /forums/images/graemlins/cool.gif
I did not realize that Power Trac reduced the price of the PT-425 by $3500 when they issued the newer version with the Robin engine!!!! /forums/images/graemlins/shocked.gif
/ 422 vaporlock #34
</font><font color="blue" class="small">( I did not realize that Power Trac reduced the price of the PT-425 by $3500 when they issued the newer version with the Robin engine!!!! )</font>
FOURTEEN, I kinda' think /forums/images/graemlins/confused.gif that johara1 was comparing the cost of a 422 (Robin) vs. the cost of your generation of the 425 (Kohler). PT certainly did NOT drop the price of the 425 when they switched over to Robin. In fact, as you may recall, they had a price jump in April-May '04 when that transition took place /forums/images/graemlins/shocked.gif
/ 422 vaporlock #35
True!
But we should keep our fruits straight! The 425 is an 'apple', and the 422 is an 'orange'!! However, while the Kohler 425 is a 'delicious' apple, evidence is mounting to suggest that the Robin 425 may well be a 'sour' apple!! /forums/images/graemlins/shocked.gif
/ 422 vaporlock #36
I think once PT gets the fuel line size, routing and heat issues solved, the Robin powered unit will be top notch(even though I still love my Kohler).
At least we have Jack to give some help while they develop their following. Can't say that about any of the other engine manufacturers. /forums/images/graemlins/wink.gif
/ 422 vaporlock #37
the 422 i have is the old one, the same as the 425 in every way except the engine. the price is the diff. between mine and the new price of the 425. i can buy a lot of high torque wheel motors and an engine for the price diff. the problem is i can't find a thing wrong /forums/images/graemlins/laugh.gif
/ 422 vaporlock #38
<font color="blue">At least we have Jack to give some help while they develop their following. Can't say that about any of the other engine manufacturers. </font>
Reminds me of that famous phone conversation:
Ring -- Ring -- Ring , , , , , , , , , , , , , Ring -- Ring -- Ring
"Hello, Kohler Tech Support! Do you want faucets, engines, or toilets?"
"Hi, I have a Kohler CH-25 and it has started to..."
"I'll put you through to toilets."
Originally seen on LawnSite.com, I think.
/ 422 vaporlock #39
Ha ha ha ha, hee hee hee hee...PLOP!!
oops... /forums/images/graemlins/shocked.gif
I laughed my head off /forums/images/graemlins/blush.gif
(That was a good one...)
/ 422 vaporlock #40
"" Hi, I have a Kohler CH-25 and it has started to..." "I'll put you through to toilets. ""
Most likely a true story!! Due to the very rare 'engine problem' calls that Kohler gets, the poor operator may not have remembered how she handled one the last time it happened!!
The best warranty is the one I never use!!
Personally, I don't want to hear: "All our staff is helping other customers!" !! I don't want to be on a first name basis with a Service Manager! I don't want a personal reserved parking spot at the dealer or service center!! I don't want to watch most of my TV in a service center waiting room!! I don't want the service center telephone number to be on my 'speed dial'!! I don't want to be part of a 'new product test group'!! Just sell me a product that does its job so well that I never have to give it a second thought!!
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2018 Blue Bird All American/All Canadian Bus (A64556)
2018 Blue Bird All...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A67148)
2016 FORD TRANSIT...
2016 Chevrolet Silverado 1500 Pickup Truck (A64556)
2016 Chevrolet...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
