422 Spyder insert disintegrated
/ 422 Spyder insert disintegrated #1
DHS
Watertown, SD
PT-422
A couple weeks ago, I noticed a loud clicking coming from the engine area of my 422. It sounded like the tappets were dancing on the pistons. After closer observation I noticed the Buna N Coupling insert in my spyder coupling between the engine and variable volume pump had disintegrated. I have an aluminum Lovejoy coupling style AL150 with a Buna N Coupling insert.
I could not find the insert locally so I ordered it from Grainger. I removed the four bolts mounting the engine and slid it back a few inches. I removed the remains of the old insert and installed the new insert.
I don’t recall reading about similar problems so I thought I would add this to our online database.
Dale
/ 422 Spyder insert disintegrated #2
That sounds about how the Lovejoy L series couplings I use with electric motors and pumps at work fail. Just a wear item I guess. It's good to know how it sounds in an engine driven application. Thanks for the info!
Dave
/ 422 Spyder insert disintegrated #3
Could be excessive mis-alignment between the engine and the pump. The coupling is designed to accomodate some mis-alignment but early failure could be telling you something. A pair of dial indicators would tell all /forums/images/graemlins/smile.gif
Rob,
I believe mis-alignment contributed to the failure. Three years ago I removed the engine to replace the charging coils and may not have had everything aligned perfectly. This time, I asked Terry at PT about alignment and he said to push the engine up tight and the alignment should be close. I measured the gaps between the two couplers and the all gaps are very close in measurement.
Dale
/ 422 Spyder insert disintegrated #5
i get it lined up the best i can by eye ,then spin the engine over with the plugs out.it will line it's self up /forums/images/graemlins/laugh.gif works for me. now just tighten the bolts without moving it.
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
Mercury Verado AMS 350 (A61574)
Mercury Verado AMS...
iDrive TDS-2010H...
2007 International 8600 Parts Truck (A63689)
2007 International...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
1999 John Deere 7810 (A60462)
1999 John Deere...
