422 New Head...
/ 422 New Head... #1
SIDETRACK
Mt Airy, MD
PT422, G4200, Scagg Freedom
I put a new head on the 22HP Robin engine on my PT422 and have it almost complete except for the throttle and choke connections. I made some notes but want to make sure I got all the springs in the right holes. I'm having the PT towed to Ditch Witch and having the valves adjusted and the float position rebuilt on the lift valve. I would appreciate it if someone could post a picture of the connections. Not sure if it matters but the oil filling cap is black and on the side of the valve cover.
Thanks
Dan
/ 422 New Head...
Thanks for the welcome. PT has been down for a while and I sure miss it's many uses around the homestead. I have a 300lb+ anvil and base I'd need to move. Dan
/ 422 New Head... #4
I sent them again and will send them here as well.
/ 422 New Head...
Fantastic, just what I need to get everything put back the right way. Thanks for the help!
/ 422 New Head...
It's a 300 lb anvil but still more then I can lift. What happened to it so it can't lift anything now is a bad valve guide.
/ 422 New Head... #8
Oh man my eyes are going bad. I am sure I saw 3000lbs but now it is clearly 300lb. Still. Big ole anvil...
I have a dream of one day replacing the control valves with something of quality.... Something that doesn't leak down, that is too over sensitive, and that has more than one control. But that is just a dream...
/ 422 New Head...
The PT was hauled out today to get the final mechanical touches. I installed a new battery that I got from the Kubota dealer since I couldn't match the old Interstate battery that I replaced. I got the Robin muffler from Northern Tool for just under a $100. I had to cut a small part off the muffler so that the motor cover could close. Looks like the old muffler was trimmed on both sides.
Hoping that when I get it back it comes off the truck a lot faster then it went on it.
/ 422 New Head...
I'll post the results when I get the PT back and get the results from Ditch Witch. I assuming they will start working on the valves and the float problem on Monday.
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2018 Calico Cattle Trailer (A64047)
2018 Calico Cattle...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
