422 engine
   / 422 engine #1
Beechwood
Could someone who has the 422 with the Robin EH65 22HP engine let me know if their Govenor springs are located in the same holes as my EH63 18HP engine. Attached is a picture of my spring setup. Thanks in advance for the help.
Beechwood
   / 422 engine #2
I've printed the photo and will check when I get home (in about an hour)
Phil
('course somebody will have already looked at theirs and posted by then, but if I DIDN'T print it and take it home, then nobody else would either. Only way to beat Murphy)
   / 422 engine #3
Mine used to be in that hole. I moved it one inward to get a little more horsepower under load increases. (Boy that will create discussion)
   / 422 engine
Bob;
Very clever! I think you know where I'm going with this. If someone were to compare the engine specifications on the EH63-64-65 they could figure out what I'm planning on doing. Were both your springs in the same holes as mine?
   / 422 engine #5
you plan on selling a used 18HP engine on craigslist someday soon?
As long as your at it, there are some small diesels that are about the same size...
   / 422 engine #6
Yes. both were in the same hole. Are you trying to get more power out of your 422? Be care, I believe the 425 engine has an oil cooler just for the engine. I just needed a little more power to get up my short hill.
   / 422 engine #7
wait a second... the 18 and 22 HP are the same engine... same displacement, same bore, same stroke, same weight, same dimensions...
hmm, there has gotta be a trick here...
   / 422 engine
Tim;
I have a few ideas but I can't say anything right now. I will say that they would benefit 180 owners with the 18 HP engine more then the 422-22HP engine owners.
Bob; I have the 18HP in my 180.
   / 422 engine #9
I may be wrong. I know I moved the spring one hole over. I am now not sure of the direction. I noticed in the service manual that the spring is shown in the middle of the 5 hole pattern. Sorry for the confusion. These engines are all identical, but there must be something different.
I now think it was originally in the middle hole and I move it out one hole.
   / 422 engine #10
I have been studying the service manual and can find no difference in the engines except the HP and Torque Specs. I am guessing that you think if you move the spring you can change the horsepower. It makes some sense. I wonder what the spring position on the 425 engine is. Does anyone know?
   / 422 engine #11
You would also have to adjust the speed stop to raise the RPM.
I may have moved my spring in the wrong direction if your theory is correct
   / 422 engine #12
Ok, the small spring on my 422 is in the same position.
The large inner "rod" is in the hole closest to the bend.
I'm out of warranty. I hope this is all gonna make sense by the time this thread reaches page 3.
I have had SOOOOO many small engines. Remember, I'm "off-grid" and have had (and still have) generators for times that solar can't keep up. I have never had a grasp of what the different holes would do, or were supposed to do. I've played with some of them before but not enough to understand the basic concept of ".... move THIS one OUT to INCREASE ..." and "... this one IN to DECREASE...." or vice versa or ?
Glad you brought this up, Beechwood.
Phil
   / 422 engine
Yes- there is something different, but someone will have to study the parts manual to figure it out!
If anyone cracks the mystery I'll buy the first beer or cocklail of their choice at the pt forum 1st. reunion being held at the govenors ball room in East Overton NJ. April 1st. 2007.
   / 422 engine
Hey guys;
Heres a little riddle and hint to ponder! -- HAVING TWO OF THESE IS ALWAYS BETTER THAN ONE.
   / 422 engine #15
The following parts are different:
Piston
Connecting Rod
Crankshaft
Governor Springs
Baffles
Carburetor
Throttle Shaft
I may have missed something.
I won't go to New Jersey (just kidding)
More changes than I would have guessed
   / 422 engine #16
Piston
Connecting Rod
Crankshaft
Governor Springs
Baffles
Carburetor
Throttle Shaft
Well it looks like a couple of those things would change the total displacement of the engine like the piston and connecting rod. Seems like the governer would make a change on the max rpm of the engine.
Hmmm april 1st in New Jersey.:)
   / 422 engine #17
What you are doing by moving the governor settings, in to allow the engine to run at a higher rpm, and therefore give some additional hp. Have you considered the fact that the engine was setup to get the highest torque at a certain rpm? In a lot of cases, more rpm is not necessarily better, and may shorten the life of the engine.
Just my thoughts. Perhaps there is a small engine engineer on this forum and can set us all straight.
   / 422 engine
Hey guys; Remember according to the engine specs. on the 63, 64, and 65 the bore, stroke, compression ratio, and displacement are all the same. So the increased torque curves on the 20 & 22 Hp engines over the 18 HP engine must be created by other means, without increasing the RPM's beyond the designed limits.
When we were all younger ( pre-computer chip era ! ) and wanted to tweak our car engines for a little more power what were the 1st. two change outs we did for not too much money ?
   / 422 engine #20
I found this in an article on the web:
The EH72 engine tops out the Robin twin-cylinder lineup, which includes the EH65 (22 hp), EH64 (20.5 hp) and EH63 (18 hp). "Our V-twin cylinder engines were originally designed for 25 hp and derated," said Brad Murphy, direct marketing manager at Robin. "The 25 hp model was originally developed for an overseas application and was not originally intended for the North American market."
Think we could find a way to "de-derate" them? :D
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2088 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2088 Chevrolet...
Chemical Containers Tank (A57148)
Chemical...
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
