42/43/4400 Loader Mounts Torque Spec?
/ 42/43/4400 Loader Mounts Torque Spec? #1
arrabil
Veteran Member
Winterstown, PA
JD 4200 & X475
Anyone know what the torque specs are on the four bolts for the loader mounts (they're called loader mounting frames in the parts guide)? Had to take one side off, they weren't torqued to more than 50ft-lbs, and I just can't believe thats the proper setting. Thanks!
/ 42/43/4400 Loader Mounts Torque Spec? #2
I think the specs are in the loader manual IIRC...I have done mine before but that won't help you.
/ 42/43/4400 Loader Mounts Torque Spec? #3
OK, I found this: 420 Owners Manual
Section : 40 under 50hr service says 255 ft/lbs. Sounds high to me...
Kenny, you were piles of help. You triggered my memory of purchasing the manual off eBay a couple years ago!
Interesting. My manual said 166 ft-lbs. But all eight bolts were down to 50 or so. I re-tightened them to 166 and added Blue Loctite. I think that'll be okay considering I didn't notice any problems at 50. Still 255 is quite a difference. I know the bolts could handle it.... I wonder if the aluminum housing could?
/ 42/43/4400 Loader Mounts Torque Spec? #5
That sounds like a better number, glad to help:thumbsup:
