42” forks
   / 42” forks #1
spechols
Central, PA
Power Trac PT425
I added these 42” frame and forks today. Lifting bigger stuff but not heavier. Got to watch the steering.
   / 42” forks #2
Very nice! I use my forks more than my bucket. You will love them!
   / 42” forks #3
I have the smaller PT forks and they saved my butt today. A shipping company just dumped a large 1000# palette labeled "fragile"..."electronic components"..."high value item"..."contact before delivery"....outside my shop. In the rain. Without calling or texting. 🤬
Quickly grabbed the PT and the forks and gently placed it in the shop before it got soaked. Apparently the supplier has been hosed like this before because inside the crate everything was shrink wrapped and had lots of extra padding...whew!
So mostly just adding to this thread to say "GET THE FORKS!" You'll be glad you did. ;)
   / 42” forks #4
how much weight can that handle, before rears lift up? just wondering. power tracs are pretty cool
   / 42” forks #5
Depends on the model.
For example, my 2001 model year PT425 says it can lift 800# at the quick attach plate. They have a model that'll lift 2400#.
What's kinda quirky about articulated machines like this is the center of gravity changes as you turn, even while sitting still. So if you pick up a heavy item, and turn the steering wheel, it'll tip forward and the rears will come off the ground. Turn the wheel back towards straight, and the rears go back down.
You get used to it.
   / 42” forks #6
You get used to it.
Fun to watch peoples faces the first time they see you do that and they think something bad is about to happen.
   / 42” forks #7
Yep. They start flapping their arms and waving while doing jumping jacks to get your attention. 🤣
   / 42” forks
I have it set up so can add 400lbs on the back if needed but I avoid doing so because I believe it stresses the articulation joint.
   / 42” forks #9
I am always on the look out for plastic pallets the wood pallets just don't last long enough.
   / 42” forks #10
i have about 40 plastic pallets. we replaced all the wood pallets with them about 10 years ago. we use the pallets under the hay stack to keep the horse hay off of the ground. the old wooden ones had to be replaced every few years. the plastic last forever.
2022 Lonestar 14ft. 5 Ton T/A Utility Trailer (A55973)
2022 Lonestar...
2015 FREIGHTLINER M2 26FT BOX TRUCK (A58017)
2015 FREIGHTLINER...
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
3PT CARRY ALL (A58374)
LOT OF TIN (A58374)
LOT OF TIN (A58374)
