Buying Advice 4120 sufficient MX6 cutter/KK 72"tiller?
   / 4120 sufficient MX6 cutter/KK 72"tiller? #1
MikePet
Upsala
John Deere 4120
I have 37 acres, 29 which are CRP grass-land. I have a new King Kutter 72" rotary tiller and will be purchasing a John Deere MX6 72" rotary cutter. I would like to get feedback from others whether or not a 2012 John Deere 4120 e-hydro (43hp, 35ptohp) would be sufficient. My thoughts are that a 4320 is another $2000, which I could use to purchase other implements. Probably buying within the next week. Thanks for your input.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #2
I run a 72" KK tiller on my L3800. 38hp, 32 at PTO. Runs it great. However, if the ground is real hard, I run it at half depth. Then, if so desired, I run it at full depth (which I never do, because it just gets to soft). So, if you want to run full depth on unturned soil on the first path, it might bog down a little. But not much.
The mower is a no brainer. It will easily handle it.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #3
You should be fine. I have a L3400 (29HP PTO) and run a 6' cutter and have ran a 60" tiller. No problems out of either.
The added HP would allow you to go a tad faster ground speed, but if you are fine doing work a tad slower, those implements will be just fine. Tilling you want to go slow anyway to get the soil really fine. So I doubt HP would be an issue there anyway.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #4
I have a 4120 and a mx6, no worries. Plenty of power.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #5
What are you cutting with the MX6? I tackle grass as well as small brush (under 2" or so, typically under 1" actually) and was recommended against the MX7... with a 4520. Dealer said grass would be OK, but getting and keeping a MX7 spinning would take all the 4520 had... which makes me wonder how the MX6 would work with your 4120 if you tackle much brush.
I had a 5' woods Brush Bull with my Yanmar (27 PTO hp or so IIRC) it worked fine but I did have to slow down quite a bit if things were thick.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #6
In my experience, grass takes the most HP. It is really dense.
Brush/weeds and an occasional 1-2" sapling is nothing. But just 18" of pasture grass will bog a bushhog down in a hurry.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #7
I'm with the consensus here, a 4120 will do just fine. Depending upon what your real needs are, you might not need that much cutter though. I got a Frontier RC20 model for my 5410 (85HP) and as you may imagine it handles it just fine. I just needed something to mow the pastures and didn't need the heavier duty model.
I will be cutting primarily light brush, less than an inch in diameter, and prairie grass. The JD MX6 is only $500 more than the Frontier RC2072 6' rotary cutter(dealer quote) so I think that is money well spent. On a side note, does anyone know if the drive-train and hydros are the same strength/durability on all the 4x20 models?
   / 4120 sufficient MX6 cutter/KK 72"tiller? #9
I was just mentioning what I've done, I'm not doing serious hogging of any sorts, just overgrown grass. I couldn't justify the extra money to do the same thing, sounds like you can.
It should be the same exact transmission/drivetrain throughout the 4x20's.
   / 4120 sufficient MX6 cutter/KK 72"tiller? #10
All the drive train is the same, 4520 and 4720 have economy pto is the only difference other than the horsepower.
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2016 GEHL RS5-19 TELESCOPIC FORK LIFT (A51242)
2016 GEHL RS5-19...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
BUSH HOG 35-06 - 6' REAR MOUNTED BLADE SCRAPER (A51243)
BUSH HOG 35-06 -...
