Backhoe 4120 simple Power Beyond Backhoe Question
/ 4120 simple Power Beyond Backhoe Question #1
rebel300r
SW WA
4120 Deere
I finally have my Woods Backhoe mounted to the subframe of my 4120 (I need to get photos up). I have the Power Beyond kit installed. The dealer says that to hook up the backhoe, I disconnect the jumper hose and leave it loose (not hooked to anything). Then he says to plug one of the hoses into the coupler above the jumper hose and the other couple goes to the smaller right angle coupler on the side. That just does not make sense to me. Can someone tell me how their backhoe lines are connected?
Scott
/ 4120 simple Power Beyond Backhoe Question #2
Scott,
He is right.. the reason for that is the return hose,
that you will connect down by the axle, gives the
backhoe an unrestricted flow back to the sump. The
circuit that is connected when your jumper hose is
plugged in is for the rockshaft. This procedure then also
takes the rockshaft control out of the picture, which for
the Deere backhoe is necessary because the rockshaft
is used to lift the backhoe up into place and then not needed
until removal of the backhoe.
does that make sense?
/forums/images/graemlins/cool.gif
Yep, it does now. I went and tried it and it worked fine. I will just bag up the free end of the jumper hose until I need it again. Now to test the subframe.
Thanks Dutch
Scott
/ 4120 simple Power Beyond Backhoe Question #4
Great,
let us know how the hoe works on your tractor.
/ 4120 simple Power Beyond Backhoe Question #5
i went to woods site, which backhoe goes with the 4120?
I am anxiously awaiting the pictures...
Can you post a link here if they go in another thread?
My bad. It is an old, big cat II Kelly backhoe off my Dad's 4020. I built a subframe over the last couple of months. I tested it yesterday and dug 5 very large stumps out of the ground! Plenty of pressure and the frame seems to take the load very well. Of course I needed a FEL bucket full of dirt to offset the weight. I will take a photo of the combo today. Now that I know it works, I am going to pull the frame back off, clean it up and paint it. I will post photos then too.
Scott
KUBOTA BT2912A - 15" PIN ON BUCKET (A64280)
KUBOTA BT2912A -...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2018 Merlo TF30.9-115 (A64119)
2018 Merlo...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
