Mowing 4115 Deere Mid Lift Mower Deck
   / 4115 Deere Mid Lift Mower Deck #1
hawk7
St. Louis Area
4115 Before
Hello To all. Its nice to be a new member of this site. I have a 4115 I restored from a fire and now have it up and running. I also restored a Hydraulic Dump System that mount to the 3 point hitch. Has anyone made up a alternative Lift System for the mower deck?? I have found the LVB25010 but it isn't for the 4115 and is even harder to locate one. I am awaiting my belly mower from CA so I haven't had a chance to look and see what options I have. Anyone with any ideas or info please let me know. THANKS Paul
   / 4115 Deere Mid Lift Mower Deck #2
Welcome to the forum.
Not sure what kind of a list you are looking for? Attachments? Mower manual? Help us out here.
Sounds like you do have the MMM deck. ANything else?
   / 4115 Deere Mid Lift Mower Deck #3
Do you have a pic of the hyd. dump system?
Sorry about that. I edited the post to read LIFT and not LIST. I have enlosed a picture of the dump collection system. I want to add a cylinder to the 60" mower deck so I can lift it instead of using the 3 point hitch. I did a search on Google for the LVB25010 optional lift kit but it is for the 4100 and 4110 deeres. This search is what landed me on this site. there was 2 prior post about the LVB25010 and one person stated that their where some post about home made lifts for the belly mowers but I never could fins them. I dont know what a mm deck is but it has a sticker on it that reads 4110/4115 60" MOW
Here is the deck
And the bracket system.
   / 4115 Deere Mid Lift Mower Deck #7
Why would attachments differ between the 4110 and 4115 ? They are both the same frame size... one with 4 more hp. Isn't there a way to mount the blower on a rigid mount ? I have never seen them both mounted on the same machine. You may have to talk to the setup person at your local JD dealer.
   / 4115 Deere Mid Lift Mower Deck #8
the 4115 has a slightly longer frame than the 4110, which
makes it capable of fitting the 72" mid mower deck under it.
/forums/images/graemlins/cool.gif
I was wondering the same thing. I thought it was the same but now I know at least 2 differences. The HP and the bigger mower. Does any body have any pictures of how the optional lift kit fits onto a 4110?? Also a picture of the back of a 4115 hitch so I can see how the decks linkage hooks to the 3 point hitch. I know the 2 black bracket hook into the same rod that the stabilizer chains hook on to but didn't know how it hooks to the 2 hitch arms. I went to my Deere dealer and they only had a 2210 and it uses the lower 2 hitch arms to push down onto a bracket to lower and raise.
   / 4115 Deere Mid Lift Mower Deck #10
Hawk7
Deere Kit # LVU14102 4110/4115 Independent mower lift system, I can email you a PDF of the installation file if you'd like.
murphy06@bellsouth.net
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
