4115 60"deck MMM install help
/ 4115 60"deck MMM install help #1
hawk7
St. Louis Area
4115 Before
4115 60\"deck MMM install help
Does any one have any pictures on how to install the mid MMM on a 4115. This is what I have but the pieces dont all seem to like up and I didnt know if I should have left over pieces.
Re: 4115 60\"deck MMM install help
Picture 2
I forgot to mention that I have the front bush gard installed so I dont need the 2 mounting plates to put on the front of the tractor. Also in this picture, part number 1 will slide into the back of the bush gard slot but then the front holes where the pin should slide threw doesnt line up. The holes are out front further. So if I have to correct part then mabey the bush guard is for a different tractor?? But it lines up with everthing when I installed it??
/ 4115 60"deck MMM install help #4
Hi
Page 30 of the MM mower ops manual shows a picture of the attaching support bracket (your "part 1" above) mounted in position. If yours doesn't fit, sounds like one of two parts you have aren't correct.
Using the support bracket you have (part 1 again) post the distance from the center of the fixed pin to the center of the pin hole. I'll check mine tomorrow (a 4110)
OK
The hood guard has a mounting distance of 4-5/8 center of the hole that part 2 (pin slides threw) to the center of the bar of part 1 (piece that hangs in hood guard hook) in the attached picture. The mounting bracket that I got (part 1) center to center is 2-1/2 ". It fits from one side of the hood guard to the other. It just isnt long enough to get the holes to line up so part 2 will slide into place to lock it in. I know the hood guard is ok since I have a front hitch that mounts up to it fine and is 4-5/8 center to center. So my question is, If i order part 1 for the 4115 will it be the correct part or will it be the same thing I have?? I bought this deck used and it came off of a 4110 but is made for a 4110 and a 4115. The deere site shows the mounting kit to fit both tractors. If you dont have the hood guard you have to buy the 2 brackets to bolt onto the front of the tractor so you can slide part 1 into the brackets. Any help would be great.
I also need to know if you use parts 11,12 and 15 in the picture I have attached. I see a place on the frame to bolt this up to towars the front of the tractor but it will only bolt up and not use the lock nut on the other side as the mounting holes are threaded. Any pictures of a MMM on a 4115 would be GREAT. Side shots,Back shots and front shots.
THanks again
/ 4115 60"deck MMM install help #7
That seems to look like the mounting parts I have on my 4100--are the 4115 supposed to be the same?
if you look it up under deere parts it says it is for both the 4110 and the 4115. Do you have yours mounted to a hood guard or the bracket? Also do you know what the center to center meassurement between the solid pin and the slide the pin of part 1?? Also does your use the LH and RH brackets. In the picture above it is numbers 11,12,16
/ 4115 60"deck MMM install help #9
I'm posting two pics. This one shows the mower mounting bracket mounted to the hood guard assembly. 4 &5/8s (notionally, +/- 1/8) is the measurement. Sounds like you have the incorrect mounting bracket (part1).
Second shot, next post, will show the the LH/RH brackets mounted on the tractor. You can see the detail of the RH bracket. Good luck---
/ 4115 60"deck MMM install help #10
This one shows the draft support brackets mounted to the frame. Arrows highlight brackets. Each is mounted to the frame using two bolts and nuts. (can't see the nuts in this pic becaue of the angle).
These are shots of a 4110. Ops manual says same parts used on 4110/4115, but no first hand knowledge of 4115. Good luck.
/ 4115 60"deck MMM install help #11
on Al3 's picture, he has the loader frames on
his tractor.. that is what the part number 12 is for,
it's a spacer to take up that space if there is no
loader frames mounted.
/forums/images/graemlins/cool.gif
GREAT PICTURES!!! Yes I must agree I have the wrong bracket for some reason. Deere want $50 for it. So I cut the 3/4 rod in half. Then latheds off the weld. I then pressed out the remaining welded 3/4 rod and filled in the 2 wholes on each bracket with weld. I will now lay it out and redo the 3/4 whole spacing to 4-5/8.
I also had to order the left side bracket that looks like your second picture. The only differance is mine bolt to the trany block and doesnt require nuts on the back.
How thick is this spacer? I will use some washers for now as I want to get a front end loader for this 4115.
/ 4115 60"deck MMM install help #14
I'd guess a little shy of 1/2 inch..
/ 4115 60"deck MMM install help #15
Do you have any additional pictures of your 4110 deck that you could post. I have a 4010 deck which I am trying to mount on my 4110 tractor. The 4010 and 4110/4115 decks are different in terms of rear connection points/brackets. I am looking for a good set of 4110 deck close-up pics to locate exact points on rear of deck for alterations (Local JD dealer suggesting re-welding rear deck connection points) so 4110 connecting hardware can be utilized. Before turning dealer loose, I would like to confirm deck alteration is doable - thanks
/ 4115 60"deck MMM install help #16
/ 4115 60"deck MMM install help #17
Here are two shots: first one is wider perspective shot from the front side. Second focuses on the rear mounts.
Pardon the dust---deck has never been used.
/ 4115 60"deck MMM install help #18
/ 4115 60"deck MMM install help #19
Pic # 2. Are you looking for some specific perspective? Good luck.
/ 4115 60"deck MMM install help #20
2021 Aquasport Boat with T/A Float-On Corp Boat Trailer (A61569)
2021 Aquasport...
2002 Sun Coast Trailers T/A 18ft Enclosed Trailer (A61569)
2002 Sun Coast...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63109)
THIS WILL BE A...
John Deere 5000-Series Loader Frames (A63116)
John Deere...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A61568)
2016 Ram 4500 Crew...
