4110 won,t start ...Gear selector switch?
   / 4110 won,t start ...Gear selector switch? #1
oscer
Central Pa.
JD 4110
Hi folks, hope you all are doing well. I was pushing some brush around today and when I put my 4110 into neutral and got off the tractor it stopped as though it were in gear, got back on and turned the key and got nothing. I think it is getting the signal that it's in gear,but I don't see any switch by the shifter. The only wiring I see is a sensor above were the shifter goes into the transmission. Any one know where this switch is?
   / 4110 won,t start ...Gear selector switch? #2
Not sure, but it is likely a stick poked up from underneath and pulled the wire off. I'd climb underneath and look for a loose wire.
Hi fellas, I read a similar post that sounds just like my problem . Thanks to beenthere for posting a page from the service manual that shows the location of the neutral safety switch.
   / 4110 won,t start ...Gear selector switch? #4
This one?
This one?
Yep, That's it. I'll crawl around under it the first chance I get and see what I can come up with. It was raining here most of the evening.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
Deere 410L (A53317)
Deere 410L (A53317)
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2018 John Deere TX (A53317)
2018 John Deere TX...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
