4110 won,t start ...Gear selector switch?
   / 4110 won,t start ...Gear selector switch? #1
oscer
Central Pa.
JD 4110
Hi folks, hope you all are doing well. I was pushing some brush around today and when I put my 4110 into neutral and got off the tractor it stopped as though it were in gear, got back on and turned the key and got nothing. I think it is getting the signal that it's in gear,but I don't see any switch by the shifter. The only wiring I see is a sensor above were the shifter goes into the transmission. Any one know where this switch is?
   / 4110 won,t start ...Gear selector switch? #2
Not sure, but it is likely a stick poked up from underneath and pulled the wire off. I'd climb underneath and look for a loose wire.
Hi fellas, I read a similar post that sounds just like my problem . Thanks to beenthere for posting a page from the service manual that shows the location of the neutral safety switch.
   / 4110 won,t start ...Gear selector switch? #4
This one?
This one?
Yep, That's it. I'll crawl around under it the first chance I get and see what I can come up with. It was raining here most of the evening.
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
2006 TerraGator 8104 (A56436)
2006 TerraGator...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
