4110 question
/ 4110 question #1
tld
Boston, GA
JD 2025r
I have a 4110 with hydraulic outlets for FEL.
While clearing brush, I jammed a stick up into the hydraulic
lines that lead to the outlets.
All seems Ok, but for some reason the lines look out of place.
Two of the lines are on the outboard side of the deck.
Can someone check their 4110 and let me know the placement of the lines. Like I say they look out of place, but might not be.
/ 4110 question #2
If you do not get any replies I will check mine after work tomorrow and let you know...
/ 4110 question #3
On mine two of the lines run between the forward and reverse pedals and two of them run to the outside of the pedals...not sure if that helps... /forums/images/graemlins/confused.gif
