4110, PTO Doesn't engage
/ 4110, PTO Doesn't engage #1
bosworth67
It took me a while to find the answer on here, so I thought I'd make this post. If PTO hasn't been used in a while, it may require a reset. The reset button is located under the floorboard where your right foot sits.
/ 4110, PTO Doesn't engage #2
I have had to push this reset button several times in the last 3 years of ownership. For me, it happens when I have had heavy use of the FEL. I have no idea why.
/ 4110, PTO Doesn't engage #3
Remove the hex head plug from the front of the block that is directly in front of the solonoid where the reset is, but be careful not to lose the spring in there. Spray some penetrating oil in the hole. This may decrease the amount of times you have to reset the solonoid. Good luck with it.
/ 4110, PTO Doesn't engage #4
Just wanted to say thanks to you and all the other dealers on here that offer help and advice. You Guys and Gals are a great help.
