4110 JD FEL
/ 4110 JD FEL #1
rloenser
New Jersey, Morris County
John Deere 4110
Hi again, I used the front end loader for the first time Sat and
put a buldge in the inside top edge within the first ten minutes of use. A rock rolled into FEL and hit inside top edge and bent the bucket. I thought this bucket was made of heavy gauge steal.. ??!!
/ 4110 JD FEL #2
</font><font color="blue" class="small">( Hi again, I used the front end loader for the first time Sat and
put a buldge in the inside top edge within the first ten minutes of use. )</font>
This is a feature. You now have a larger capacity FEL bucket than you had before.
Which bucket do you have?
Cliff
/ 4110 JD FEL #4
I have a 410 FEL but I think my bucket is smaller than yours and its pretty heavy. Never had any problems like that, but then again we don't have any large rocks here on the eastern shore of NC
/ 4110 JD FEL #5
I have the 49" bucket and have beat the beens out of it and have little damage. I would`nt worry about it, I have used mine so often half the bucket is polished steel from all the abrasion.
/ 4110 JD FEL #6
[quote}
)</font>
Thats a riot, I laughed out loud.
/ 4110 JD FEL #7
I have a 410 loader with a 53" bucket, mounted on a 4115. I've had it for two years now. I beat the snot out of it and have only bent the top edge a little. You might have caught a rock the wrong way. If there is such a thing. /forums/images/graemlins/grin.gif
Dave
/ 4110 JD FEL #8
I have a 49" bucket on a 4115 and I also have beat the heck out of it. I have seen it flex a little if I catch a thick root in the center of the bucket and lift with all it has, but it always has popped right back when I released the load. I grew up on a farm using much larger tractor/loader combinations and I have am amazed at how tough this little tractor and loader is!
/ 4110 JD FEL #9
I have the 61" bucket on my 410 loader and haven't had any problems...yet... /forums/images/graemlins/smile.gif
/ 4110 JD FEL #10
...same with me.....same FEL and bucket, no problems...
2014 Kobelco SK210LC Hydraulic Excavator (A66734)
2014 Kobelco...
1997 FRAC TANK 500BBL WHEELED (A68842)
1997 FRAC TANK...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
Unused CID FDM60-S 60in. Hydraulic Forestry Disk Mulcher Skid Steer Attachment (A66734)
Unused CID FDM60-S...
