4110 Hyd Canister Leaking
/ 4110 Hyd Canister Leaking #1
BillBee
Bronze Member
VT / RI
Mahindra 4110 / Husqvarna GT48XLS / 18HP Garden Tractor & ATV Artic Cat 400
I changed the hydraulic fluid and filters today and discovered the canister O ring was broken from the last changed performed by a dealer. Due to leaks, I will need to redo and replace the canister O ring. If I open the canister to replace the O ring, will I loose all the fluid or just what is in the canister?
/ 4110 Hyd Canister Leaking #2
You will lose all of the fluid, unless you can plug the line on the other end of the canister some how.
Thanks Galen, it looks like I will have to catch the fluid and refill.
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
CASE  721F WHEEL LOADER (INOPERABLE) (A67714)
CASE 721F WHEEL...
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
1600 GAL WATER TANK (A68842)
1600 GAL WATER...
2012 JOHN DEERE 700K LGP CRAWLER DOZER (A65056)
2012 JOHN DEERE...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
