4110 has a pto whine
   / 4110 has a pto whine #1
coffeeman
Platinum Member
Hi all
Can anyone guess if this sounds ok.
When cruising along with rotary cutter running I hear a whine in pto. About 1/2 speed not much load hit a bump and err..err..err...err...err. Sounds like an old manual trans pickup as it lobs over a hill and sort of coasting on level. When I shut pto off it quits, so I guess it's pto. I can't remember if this is normal as of last year. I can't find tractor manual to check if I missed some oil check point. I'll have to look for it as they are expensive.
Cheers...Coffeeman
Hi all
Cheers...Coffeeman
   / 4110 has a pto whine #3
Check your Hyd. fluid level first before you use it again.
Have you changed it since it was new?
Ernie
   / 4110 has a pto whine #4
Ernie
   / 4110 has a pto whine #5
Coffeeman,
I second the hydraulic fluid level check (rear end).
My 3510 (same tractor, smaller motor) just started the same thing. When PTO all the way up, some whine, especially when unlevel.
I checked the fluid, it is low. Not out, and whine goes away when lowered slightly and top tilt cylinder closed.
It just happened and I checked the fluid (while running) and parked it. I'll put fluid in it as soon as I get the chance.
Sort of like the whine power steering makes when low....
-DiskDoctr
   / 4110 has a pto whine #6
Coffeeman,
-DiskDoctr
I changed all the oils at 60 hours. (I'm pretty sure I got all of them.) Where do you check the fluid? There is a dipstick on the rear left axel. Darn, I gotta find that owners manual.
Coffeeman
Coffeeman
Yes
It's like a power steering whine.
Cheers....Coffeeman
Yes
Cheers....Coffeeman
Heavy-Duty 3-Point Bale Spike - Efficient Hay Handling for Tractors (A52128)
Heavy-Duty 3-Point...
1267 (A50490)
1267 (A50490)
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
7022 (A50322)
7022 (A50322)
