4110 4WD NOT WORKING
/ 4110 4WD NOT WORKING #1
cajunmike
I HAVE A 2001 4110 WITH 250 HOURS.I HEARD A NOISE FROM THE DIFFERENTIAL. THE SHAFT IS TURNING WHEN I PUT IT IN 4WD. HOW HARD IS IT TO LOOK INSIDE THE DIFFERENTIAL AND CK THINGS OUT.THANKS
/ 4110 4WD NOT WORKING #2
/ 4110 4WD NOT WORKING #3
First thing I would do is drain the diff oil in a clean pan and check for metal pieces or shavings. The drainhole isn't hardly big enough to get much of a look inside, the only way to really inspect it is to remove the axle assembly from the tractor and remove the diff. from the housing. I would also drop the driveshaft and check the splines & couplers on each end of it - you have to remove the tube surrounding the driveshaft at the same time but it's not very difficult. Then again, you might have a final axle or drive problem and the noise is being transmitted thru-out the axle assembly. With the front wheels off the ground and the driveshaft out, you'll be able to pinpoint the source of the noise rotating the wheels and/or pinion shaft by hand. Have a friend turn the wheel and use a long 3/8" drive extension as a "stethescope", holding against different areas to loacate the problem area. I've done my share of axle & diff. work on my 4110, believe me, in can be anywhere in the front axle assembly. Oh yea, each final drive has a drainplug too, if the noise is in one of them you can drain the oil in the clean pan as for the diff. to check for shavings etc.
THANKS FOR THE INFO. I WILL TAKE IT APART WHEN I GET OFF THIS OIL RIG
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
SDLOOL SL36C (A64912)
LOOK! (A63111)
LOOK! (A63111)
John Bean B600P Commercial Wheel Balancer (A64912)
John Bean B600P...
