4100 battery cable "extension"
/ 4100 battery cable "extension" #1
acs55812
Duluth, MN
4100 battery cable \"extension\"
Has someone put an extension on the battery cables (or maybe just the positive) on a 4100. My thought is that if it fails to start its going to be on a very cold misereable day and getting to the battery to jump start or to even maybe to keep a charge maintainer on it would be nice to have a convenient location to hookup. Any ideas of how not to have the positive exposed to shorting out?
Thanks
Dan
/ 4100 battery cable "extension" #2
Re: 4100 battery cable \"extension\"
I have an extension on the positive terminal on my JD4200. I use it when I want to hook up an electric winch without getting under the hood and removing the grill. I took a 40 inch piece of battery cable (switch to start 4 gauge with ring terminals on each end)and hooked it to the positive terminal and led it under the side panel. I covered the exposed ring terminal with a length of rubber hose that I can slip up the cable when I need power. I have had it that way for 4 years and never had a problem. It would serve the purpose of providing a location for a jump start or battery charger as well as a location to hook up an electric winch.
Bill
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
Kubota M125X (A60462)
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
Freightliner Cascadia (A63689)
Freightliner...
2012 Ford Expedition SUV (A61574)
2012 Ford...
