410 loader cylinder repair?
   / 410 loader cylinder repair? #1
bucknut
Illinois
JD 4100, JD 140, JD 110
Does anyone have a service manuel for a 410 loader(on a JD 4100 CUT)? I blew a seal and was trying to disassemble it to replace the seal. I got it apart, but may have tore it up. The ser # is less that 8801. There is a wire lock of some kind that locks the rod end of the cylinder to the cylinder tube. I would like to know the proper way to remove it, and install the new one. Thanks for any help.
   / 410 loader cylinder repair? #2
I have done it, and described the procedure before. Take a look at THIS post and see if it answers your questions, if not-ask away:D
   / 410 loader cylinder repair? #3
Dang Kenny, you da man!
Pictures and more pictures. We can walk you thru most any cylinder rebuild with pictures. There are so many ways for these things to be put together it ain't funny! I have to admit, sometimes I even get fooled. Some little snap ring inside that I didn't see. Darnitall! By the way, that's the name of the pain killer I am going to invent. If it will cure the darnitall, it will cure anything!
Thanks for the help. I read the post, but it seems the cylinder is made different. Mine has no snap ring on top, it is solid. It seems to be retained by a round wire ring that protrudes through a slot in the cyl tube. I thought it was threaded on and used a pipe wrench, which broke the wire ring, and I had to pull it out by breaking it in pieces an pulling out through the slot.
I attached some pics of it disassembled. I would like to know how I should have done it, and how to get it back together. If you have any experience with this type please enlighten me before I have to buy a new cyl. Thanks
I forgot to attach the pics
   / 410 loader cylinder repair? #6
Ah yes, I thought this was it by the way you described. On your cylinder, that wire is what holds the gland in. Lock your cylinder in a vise with the groove up. Now while turning the gland, stick a pick down in the groove and catch the end of the wire as it comes around. You want to guide the wire out of the groove as you turn the gland. When the wire tries to come out of the groove, the gland will become harder to turn, just give her a little extra, it will pop out. You will need a good pick so it does not bend. After the wire is out, use the rod like a slide hammer and pound the gland free. Just be careful as oil will go flying everywhere. I've lost many a good work clothes and shoes doing this. I've even stripped right there and used my clothes to soak up the oil. I don't know about you, but in my case, it wasn't a pretty sight. Let us know how you do.
Andy
Oops, just saw your pics. Already apart, okay, disregard. Looks like you boogered her up a little, but should be fine. Anyhow, the above is the way it's done. Sounds like you did all you could to do it the right way. The ring broke, this is common. Get a new one, slap it together. Looks like an easy cylinder to do. Good luck.
   / 410 loader cylinder repair? #7
OK, I missed the part about the serial #. I just looked them up on JDParts. I have not taken this type apart, hopefully Andy can help when you get the pics posted. I will post the parts breakdown...
   / 410 loader cylinder repair? #8
Andy
NO You are!:D
   / 410 loader cylinder repair? #9
Okay, to install the new ring. Put the whole cylinder back together. The ring is the very last step. I like to put a little grease on the o-ring by where the retaining ring goes. Line up the hole in the retaining ring groove with the groove on the cylinder housing. Slide the gland into the cylinder until you can see the hole in the gland. There should be a little hook on the new ring. Put the hook into the hole in the gland. Now turn the gland with your pipe wrench drawing the ring into the cylinder. I like to put some grease on the ring so if you ever have to remove it again, it's a little easier. It's just that easy!
Thanks, you guys are awsome. I am going to the dealer to get the seal kit Tuesday. I would not have thought to "roll" the new retainer in through the slot. Thanks again Wayne County Hose and KennyD.
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
Fire Hose W/Holder (A50774)
Fire Hose W/Holder...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
