410 FEL leaking
/ 410 FEL leaking #1
GaryK
NC
JD 4100 HST
After a few hundred hours, my 410 FEL finally has a leakdown in one of the lift hyd cylinders. The bucket will drop pretty quickly with a load in it and does make a weird sound in one of the lift cylinders when being raised. I guess its time to overhaul the bad cylinder. Would it be wise to do both while I am at it? And does anyone have a breakdown schematic of the lift cylinder or know where I can get one.
/ 410 FEL leaking #2
I would recommend that you do both. Also you might want to compare the cost of doing it yourself or having them repaired and buying new ones. Doing it yourself is definitely going to be cheaper, as you know but sometimes if you are in a hurry, the other options can be considered.
/ 410 FEL leaking #3
GaryK,
</font><font color="blue" class="small">( And does anyone have a breakdown schematic of the lift cylinder or know where I can get one. )</font>
The closest that I have seen is the exploded drawings on JDParts.
