40K max
/ 40K max #1
JimMorrissey
Southern Maine (now)
'05/'06 L39 TLB
Hi. I know this is going to sound odd, but I refuse to pay more than 40K for a tractor and loader. Would be nice if it had a cab, and might be willing to go 42K, but that's it. Only other caveat is that I need to lift just under 2K lbs with a set of forks. I don't really need much from the rear of the machine. I'm moving metal totes of firewood. Needs to be a new machine. Any suggestions?
/ 40K max #5
/ 40K max
Again, for the umteenth time.. Whatever you buy, buy from a local dealer because you will need that dealer at some point.40 grand today won't get you much I'm afraid.
I actually could care less about the local dealer. I am the warranty
/ 40K max #11
How high do you need to lift 2,000 pound metal totes of firewood?
How smooth and level is the ground you will traverse?
A 3,700 pound bare weight Kubota tractor will be sufficient for some, but fairly tippy and may not lift high enough for you. (Kubota MX, Kubota Grand L with LA1065 Front End Loader.)
Personally, for safety reasons I recommend a Kubota M series.
Kubota M6060 Weight
5005 lbs (4WD ROPS)
2270 kg
5358 lbs (4WD Cab)
2430 kg
LA1154 Loader / Power Position
2928 lbs lift (full at pin)
1328 kg
To lift 2,000 pounds to full height with a M series you will still need ~ 800 pounds ~ of counterbalance mounted on the Three Point Hitch.
VIDEOS:
/ 40K max #14
Using your parameters, you cannot buy a new Kubota that accomplishes your goal.
Their lift capacity at that price point is woefully less than the competition.
/ 40K max #15
I like my Kioti; But TYM 574 HST open station falls well below your budget, even if you throw another $850-1200 on for forks. You probably could get the cab version within your price limits.
/ 40K max #16
If you want specifically a Kubota, MX6000, open station, just might squeeze in under $40,000 with a set of forks, assuming your state exempts ag equipment from sales tax.
/ 40K max #17
You should be able to get an MX5400 for that.
I’m pretty sure when I got a quote for one a couple months ago it was under $40k for tractor with loader
/ 40K max #19
Find the nicest pre emissions unit you can. This will allow you to go bigger, be safer, get your loader & cab and probably wind up with a more reliable tractor.
/ 40K max #20
Consider a rear engine Skid Steer, rear engine Compact Track Loader or rear engine, articulated Wheel Loader in lieu of a front engine tractor.
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
King Kutter II Tiller for sale.
King Kutter II...
2013 Dodge Charger Sedan (A61574)
2013 Dodge Charger...
Caterpillar TL1055D (A62177)
Caterpillar...
