2022 4066r purchase and setup!
/ 2022 4066r purchase and setup! #81
A couple of points. A lot of attachments can be had with the JD quick attach setup for the FEL. It sounds like you are going to get a grapple and the bucket, you should be fine with the JD setup.
The quick hitch on the back will hook up to most newer implements. I’m not sure why the dealer said that. There is a standard spacing that is required for the quick hitch and most newer implements will work. Sometimes the top hook up won’t quite work but someone makes and extender type setup for it.
Better to get the SSQA attachment from JD if you can. Then you can buy any used attachment you want instead of being limited to just JD which is a Much smaller pool to pick from.
We are staying with JD attachment system. I have used SSQA quite a bit at my old job and did have buckets fall off while back blading. Nonetheless, with just a bucket an grapple being used, why spend the $$ for a SSQA front plate? Nearly all attachment manufacturers offer the JD mounts anyway AND they might stay on better. :)
/ 2022 4066r purchase and setup! #83
Looks nice but i have to ask a question. 4 years old and they have not been able to sell it? And my thoughts are should be full warranty as they own and know the machine and its, 20 hours,
In searching the tractor sales sites, I see multiple JD demos listed, many 3 or 4 years old.. We asked about the warranty and learned that JD starts that at day one of there demo life, so it has 2 or so years remaining and they do not offer extend ones. We asked.
/ 2022 4066r purchase and setup! #85
Ok but what does it tell someone when they have a 3 or 4 yr old machine they can not sell?. Not being a tractor guy too me it says not a popular model, maybe because of design or flaws or way over priced.. Not sure if JD puts the equipment on consignment or the dealership has been making payments, if they have been making payments for 3 or 4 years yet still own it then to me red flags are waving.. You dont see new 3 yr old cars at the Ford dealership, maybe farm equipment is different
/ 2022 4066r purchase and setup! #89
/ 2022 4066r purchase and setup! #91
Also comes with this 3-point quick hitch. The dealer said "they won't attach to many implements". I appreciate his honesty. Bucket looks unused!View attachment 5495944View attachment 5495942
With the adjustable top hook like that, and having the proper bushings, I use my quick hitch no problem on implements that are "not quick hitch compatible"
/ 2022 4066r purchase and setup! #93
As for backhoe's on a small tractor, I'd never buy one again. I used mine once to dig a grave for a pet. I have LOTS of other digging work I'd like to do, but it's such a pain in the butt to take on and off, and when it is on you spend more time repositioning the tractor than you do digging. I should have put that money towards a mini ex.
The only good thing about the backhoe for that cabbed John Deere is that it has it's own seat. So like others have said...bring someone with you to stay in the cab and move the tractor and one person stay on the hoe. Then maybe you can get some productivity.
/ 2022 4066r purchase and setup! #94
I think R1 tires are a good pick for your needs.
I'm assuming this is an HST tractor? I think all the 4R tractors are, but I'm not certain. I think an HST is very important for your use.
After owning 3 different tractor backhoe attachments over the years, I'd would suggest you not waste your money or time on one. I just kept hoping they'd get better on bigger tractors, but they are not. They are just too much of a compromise. If buying a used mini ex isn't viable, then I'd prep and accumulate projects, then rent one for a week or whatever. Tracking a mini ex down a bunch of woods roads is not a big deal. I regularly move mine 1-2 miles. A 2 mile trek will take 30-45 min. Just plan your work so you aren't moving around more than necessary.
I'd ask to see the Deere records for the machine. It should show the in-service date which is when the warranty starts, plus the end of warranty date. I'd be surprised if there is any warranty left if it started when it became a demo roughly 4 years ago. My 6 series Deere has a 2 year warranty.
Confirm the machine is really a Demo always owned by the dealer, and that it wasn't actually sold then traded back.
The records should also show who all work that has been done on the machine. Make sure all the prep was done as expected, plus follow on service. It doesn't have a lot of hours, but many service tasks are time based as well as hours based.
And especially check the records for any repairs. I would also recommend personally checking the torque on all the loader frame and tractor frame to engine bolts. There are many reports of these bolts coming loose, falling out and all sorts of consequential damage. I would witness mark all of them after checking, then keep an eye on them.
I think you will discover pretty quickly that a hydraulic top link for the 3PH would be super useful, not just for hooking up implements, but also for adjusting their level as you work. I find it's one of the most commonly used controls when working with a 3PH implement.
Just a quick comment that the "deere hitch" on this tractor is NOT the same as a "Euro" or "Euro/Global" hitch. There are some similarities, but the Euro/Global hitch doesn't enter the Deere line until the 5 series, and becomes common place in the 6 series.
Make sure it's clear whether transportation and/or road service is part of the warranty/extended warranty. If not included, and if you can't trailer it yourself, this can create a bunch of out-of-pocket expense for "free" warranty work, especially if the tractor has to go back to the dealer multiple times to find something, which seems to be all too common.
Check up on the dealer's reputation for service. Dealer hate seems to be a growing thing, especially as family dealerships get rolled up into corporate behemouths.
/ 2022 4066r purchase and setup! #95
That looks nice. I have a 4044M. That one looks like it has a lot more bells and whistles than mine. I considered a cab, but I think it would get in the way when I'm hopping on and off the tractor a lot. It would be nice in cold weather or when mowing a large area, though. If I have either my scraper blade or mower on the back for ballast if can easily lift the big round hay bales. I use it to move them after my hay guy cuts and bales. Also to feed the cows. The only real issue I ever had with it was when a squirrel built a nest under the hood this last December or so and tore up a bunch of wires. It still started but had a stop alarm on it and was running rough. I think I've had it around 10 years or more. I don't exactly remember. I considered the 3 series and 5 series at the time and decided 5 was overkill for me, and 3 might leave me wanting more tractor. That one should do a lot of what you need. I didn't read the whole thread. Good luck on it.
Northland JD who I just got back from has dealerships here in the UP, northern WI and two in northern MN. I would call them a larger dealership. They have another 4066r demo at another location with those the r-4 tires which would be better for us working in off road conditions. Lots better than the Nokia snow tires! Its got a few more hours and a bit lower in price. The machines we are looking at are HST but JD does offer power shift as well.
/ 2022 4066r purchase and setup! #97
Those Nokian tires will have more grip in mud then the R4's by far.
In my opinion R4's are worthless on anything but pavement or hard gravel.
I just left the dealership and the tractor on my right has r4's while the 4066 on my left the Nokia R14's. The 14 had much tighter tread pattern and filled with rubber like turf's, than the R4's do. Have you used them both? Seen them side by side? The r4's and not a ag tread but far closer than the Nokia's snows are.
/ 2022 4066r purchase and setup! #99
Yes I have used R4's and they are an accident waiting to happen on hills with just wet grass they are not worth much in mud either.
No I have not run the Nokians, but I have and am running a BKT with the similar tread pattern and am pleased with there traction and performance.
I also have a little Kioti with the R14's on it and they do very well;
And then my NH 8160 and IH 574 are both dressed with R1's.
/ 2022 4066r purchase and setup! #100
Agree, but adding an hydraulic top link improves the iMatch quickhitch many, many fold as well.
