4035HST timing adjustment
/ 4035HST timing adjustment #1
Sysop
Elite Member
Fairmont, WV
Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
Well, I'm getting ready to get into adjusting the timing on my 4035HST. My tractor has displayed all the same signs as everyone else's that has had the timing issue. I'll go through the whole story here so everything is in one place, and hopefully get folk's opinions along the way.
Bought the tractor last summer and everything was golden. I have two "issues" that seem to point to the same thing.
First, within the first 20 hours, I had noticed that after running for 20 minutes it would sputter and miss for a minute, then recover and do fine the rest of the day. I researched and learned of the KSB timer relay that advances the timing for the first 20 minutes before turning off, and the sputtering was due to the timing being slightly retarded when the timer timed out. I learned in that research that it was a common thing, and some units needed a timing advance on the pump to correct things if it became an issue. No problem, I can live with it sputtering for 30-60 seconds 20 minutes after first starting it, because I generally let it warm up and am just getting implements ready to go when it happens. Once I'm in the field, I never see the issue...
Second "issue" has became starting the tractor. When I first got it, I would turn the key to the on position, wait on the glowplug/intake air heater light to go out, the tractor would start within 5 seconds of cranking using no throttle. I didn't use the tractor any over the winter, but I did start it at least every other week and let it run about 30 minutes each time. This past winter was one of the coldest in many years. When it was especially cold in the barn, it didn't always want to start right away. So, I would wait on the glowplug light to go out and cycle the key off and back on to put it through another cycle. Then it would fire up fine. Once the weather started to warm back up, I had noticed it was still requiring two cycles of the glow plug and even then it still wasn't starting as easy. I went back to a single cycle of the glow plug and no change in the way it was starting versus two cycles of the GP, and it has since continually became increasingly difficult to start.
NOW, these issues have both progressed to a point that I need to go ahead and do something about it. When I leave the tractor run to warm up, anything less than 2000RPM and it will die when the timer kicks off. If I do not cycle the key off and simply try to start it, it will not start (cycling the key off reinitializes the timer relay and advances the timing for another 20 minutes and it is fine).
From my understanding, the initial "fix" from Mahindra is to replace the KSB timer, if that doesn't work, they advance the timing on the pump.
I think the KSB timer swap is a "shot in the dark"/"hope this fixes it" type thing as the old unit does as it is supposed to and advances the timing to make cold starts easier, it is once that timer is off that the issues really show up. In reading all I can on hard starts and sputtering after the KSB timer shuts down, the most common cure seems to be manually advancing the pump itself.
OK, so I've done the research on advancing the pump, that has led me to a new query... In visually inspecting my engine, it appears the pump is nearly rotated as far as it can go in one of the two directions. I'm sure it hasn't moved since it left the factory as there is not only a coat of paint that was applied after assembly that is flawless, there is also an alignment mark that indicates the factory position and that is perfectly aligned.
What if I make the adjustment and it helps but isn't enough? What needs done to correct the issue? Most likely it will go back to the dealer for anything more than what I'm into already, I'm mainly curious.
I wanted to try the timing adjustment on my own because sending the tractor to the dealer for an unknown amount of time for a 20 minute fix isn't appealing to me at all...
Below is an image of the timing marks and you can see how the bolts are not centered in the slots.
Well, my concerns were somewhat justified. It needed to go the direction with the least amount of travel. With it set as shown, it starts like new. I will be running it some in the next few days and see how it performs and report back.
Well, I've got about 8 hours of operation on the tractor since making the adjustment. Everything seems MUCH better. The engine still dies if idling when the KSB timer kicks off, but it is now able to be started without cycling the key off and back on to reset the KSB timer. Just give it a little throttle (makes it start at about 1100-1200RPM) and it takes back off with a 6-8 second grind on the starter. If I have it warming up at 1200RPM when the KSB timer kicks off, it sputters but doesn't die, which is closer to how it was when new.
Does anyone know if the KSB timer replacement Mahindra normally does in this situation, is an updated part? Is it a new number? I'm considering asking my dealer for one to see if the transition is not as abrupt when it kicks off, perhaps that will prevent it from dying.
/ 4035HST timing adjustment #4
Im a total noob asfar as deisels go, so all I can contribute is...is it under warrentee? The 5 year powertrain ought to cover it. Sounds like you've got a lot more than 20 minutes into it. :)
It is, and it should be, and if the adjustment allowed externally on the mount doesn't allow it to be adjusted far enough, the dealer will be the one to sort it out... The way I see it is if it wasn't meant for users to adjust, the adjustment would be designed internally where it cannot be done without training specific to the machine and it wouldn't have a "range" of adjustment available before it becomes a major undertaking. Actually no, I only have about 20 minutes invested making the adjustment, which included "customizing" a wrench to reach the rearmost nut without having to remove the air intake tube from the air filter... The rest of the time has been operating the machine at various tasks around the property to test it.
It just so happened my travels today took me near enough to the dealer with enough time to spare I stopped in and popped the hood on one of the new 4035s and looked at the KSB timer. It appeared from memory to be an updated part, so I went to the parts guy to have him order one, but he had two in stock already. I walked out the door with the new one in hand (free/warranty) and will be trying it in a couple hours.
Well, not so great of a result, but nothing that can't be tried again. When I had stopped at the dealer earlier and picked up the part, his computer only showed one in stock, but the bin had two in it. Neither of us gave it a thought, he just handed me one and out the door I went. Got it here and unboxed it, it is one month newer than mine...
I also noticed it has some dirt on it, not likely is it a new part... I tried it just to see if there was any variation in the operation of the tractor, everything remained the same. I'll stop and trade him for the other one in the drawer, hopefully it is the new one the computer database indicated was in stock...
/ 4035HST timing adjustment #7
Well hopefully that works. Sounds like you are on the right path.
Well, the other they had in stock was also June 12. I don't think it's going to do me much good to change it with the one. The mechanic said it could also be drawing air on the fuel line, but that doesn't explain the fact it is fine until 20 minutes each time. I'm just going to run it and live with the sputter at 20 minutes and let him change the fuel line this winter unless things progress... I can live with a machine that is 100% usable except for 3-5 seconds of sputtering 20 minutes after being started as long as it doesn't die and doesn't get worse...
/ 4035HST timing adjustment #9
one question that may/may not mean anything:
is it a Tier 4 engine?
Advertised as Interim when I bought mine. Now they just say it "conforms to EPA TierIV norms". There is no difference between mine and the new ones on the lot except two years between the build dates. Of course that's not to say there isn't some new programming or settings that aren't visible.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
