4035 - Operating RPMs for HST
/ 4035 - Operating RPMs for HST #1
jjmaes22
Bronze Member
Chester, IL
Mahindra 4035 HST
Just wondering about anyone else out there with an HST - esp a 4035 - what RPM range do you find yourself operating at?
My 4035 seems very responsive (forward / reverse, in low, med or high) when I am around PTO speed or higher (really just ever higher when I am in the road in high trying to get somewhere - or when I am pulling the 2 bottom plow).
Below that RPM level - it just seems very slow to respond to pedal controls.
Anyone else seeing anything like that? or just?
/ 4035 - Operating RPMs for HST #2
Now I only have about a dozen hours on my 4035 HST, but I too find that around the PTO speed mark (2000 engine RPM?) is where I seem to do most of the work. Don't have any experience with any road driving or pulling something like a 2 bottom plow.
Typically when I think it is responding slowing (not moving as fast as I expected) it is because I have it in Low or Medium instead of in Medium or High where I 'thought' I was.
Martin
/ 4035 - Operating RPMs for HST #3
I operate well below PTO speed 90% of the time.. It just depends on what I am doing and how responsive I want the FEL controls to be. Usually 1800 to 2000 rpm for most things. sometimes even less. The hydrostat itself responds fine to the lower RPM's.
/ 4035 - Operating RPMs for HST #4
I run my 4035 shuttle in the 2000 rpm range most of the time doing light yard and snow removal with the fel.I notice a big diff. when running in 2nd to 3rd gear
So it sounds like the 2000ish RPM range is a sweet spot for this tractor. I see alot of people running alot lower - but maybe something unique to these setups
/ 4035 - Operating RPMs for HST #6
In my experience, which has been very limited, it has always seemed hydrostatic equipment operates with less long term issues at higher engine RPMs. I have been told the more "whining" a hydrostat is doing, the more wear the operator is causing. Going to a higher RPM and/or lower gear will minimize the "whining" noises and the wear inside the hydrostat. The way I understand it, the extreme pressures created inside a hydrostatic transmissions creates allot of heat, the more fluid there is pumping through the system, the faster the heat is removed.
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65056)
2021 CATERPILLAR...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2007 KENWORTH (INOPERABLE) T880 (A67714)
2007 KENWORTH...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
