4025 Starter Issue
/ 4025 Starter Issue #1
hayboy48
West Central Alabama
Mahandria 4025
My 4025 has been giving me starter problems. I can cross the main post on the solenoid and starter works, when you try the key nothing. Not a mechanic so I think solenoid is bad, then I see a starter relay is involved. Help and THANKS
/ 4025 Starter Issue #2
If you have a multi-meter, check to see if you have power getting to the battery side of the solenoid. If you do, then it's not the relay. (You may have to turn the key on to check this, as the relay needs to be engaged)
If no power to solenoid, then pull the relay, switch it with another relay in the box (same type) and see if the starter works that way. If so, then you do have a bad relay.
But before anything, remove and clean the battery cables and terminals, and trace your ground to the frame and remove and clean that. Many times it's just a bad connection on the battery terminals, or the ground.
Edit: Also, do you have dash lights come on when you turn the key on?
There is a fuse located all most on top of injector pump. I don't see what I call a relay yet. Will do some checking. Thanks
2022 EZ-GO ELITE...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 BERGMAN C815S ARTICULATED DUMP TRUCK (A65053)
2020 BERGMAN C815S...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
SEARS ELECTRIC AIR COMPRESSOR (A64276)
SEARS ELECTRIC AIR...
