4025 clutch out?
/ 4025 clutch out? #1
Ruark
Mahindra 4025
I love my 4025, but at 110 hours the clutch is already slipping. Sometimes I'll be using it - say shredding a pasture or just going down a dirt road, and the tach suddenly starts spinning up to 3000+ rpm and then back. I'm very careful with the clutch - I never slip it. And when moving out, I gently let it out at idle and then apply the gas pedal. I've used the loader quite a bit, but not excessively.
I remember reading somewhere that these tractors often had clutch issues. Anybody? Like I said, I love the tractor, but a clutch going out at 110 hours is kinda hard to swallow.
/ 4025 clutch out? #2
Perhaps the freeplay wasn't set properly in the peddle. If the peddle is set too tight it can reduce the life of the clutch.
Is it still under warranty?
/ 4025 clutch out? #3
How much pedal free play do you have before you feel tension on the pedal?
/ 4025 clutch out? #4
How much free play should there be?
I want to check mine now!
/ 4025 clutch out?
There's quite a bit of free play, but keep in mind that this is a two-stage clutch. The lower part of the pedal travel engages the PTO. The upper part engages the regular clutch. So it's supposed to travel a long way before engaging.
/ 4025 clutch out?
There should be about an inch of free play.
Lawalls, can you give me a little specific information about this free play - where it is, how to measure it, etc.?
2017 Chevrolet Impala Sedan (A66738)
2017 Chevrolet...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2012 TEXAS PRIDE T/A GOOSENECK TRAILER (A67714)
2012 TEXAS PRIDE...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
2018 FORD F-150 (A67714)
2018 FORD F-150...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
