4020 Series Specs
   / 4020 Series Specs #1
timb
Southwest PA
Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
Just got back from my dealer - no luck finding me a 4710 reverser /forums/images/graemlins/tongue.gif but my name is already on the first 4320 that comes in /forums/images/graemlins/grin.gif
Here are some brief specs for the new large frame JD Cuts. Some may be redundant with previous postings - but here goes:
Four models, 4120/4320/4520/4720. The 4120 and 4320 are the replacements for the 4610/4710 respectively. The more powerful 4520/4720 go into new territory power-wise but are the same chassis. All are MFWD. All specs listed below are in the 4120/4320/4520/4720 order.
ALL models use 4-cylinder, 149 cu in (2.44l) John Deere PowerTech turbocharged diesels. Engines now have glow plugs.
Gross Horsepower - 43/48/53/58 at 2400 rpm. (note new lower rating speed).
PTO Horsepower (reverser) 35.5/40.5/45.5/na
PTO Horsepower (hydro) 35/40/45/50
(note - only reverser and hydro trannys available - and hydro only on the flagship 4720)
Torque @ rated speed 91/102/113/123
Peak torque @ 1440 rpm 109/127/141/154
(I think that's a better rise than before).
Implement hydraulic flow is up - 12 gpm vs. 10.6
Steering hydraulic flow is down 5.1 vs. 5.3
Total 17.1 vs. 15.9 GPM
Pressure's the same (2500psi) as is 3 point lift capacity and class (I).
Overall weight is up - 3700 lb vs. 3450 lb.
Fuel capacity is up 14.5 vs. 12.5 gallons.
Unfortunately no pricing or other specs available yet. The dash layout is changed but the pic on the one-sheet is too small to make out much. Cannot see a fuel filler opening on the hood in the photo, but it's a bad angle. Likewise from the one rear shot can't tell if it is now a rear tank or not. They are supposed to start shipping Monday (6/7).
Tim
   / 4020 Series Specs #2
The link went out on the other 4020 thread so I will post the pics here
   / 4020 Series Specs #3
   / 4020 Series Specs #4
   / 4020 Series Specs #5
   / 4020 Series Specs #6
   / 4020 Series Specs #7
<font color="green"> ALL models use 4-cylinder, 149 cu in (2.44l) John Deere PowerTech turbocharged diesels. Engines now have glow plugs. </font> .
Are you sure they are ALL Turbos? It seems to me that there are an awful lot of versions for just detuning the injection... Would make a lot more sense that there are two injector setups, and then with normal or turbo aspiration, to make four versions. But then, nothing HAS to make sense...
Looks like the hood is one piece, thats great
The brakes are on the right, I guess thats a reverser in the pics.
Nothing new in the rear. How hard is it to hook up the pto shaft with iMatch in the way?
I looked at NH a lot when I was buying. I felt that the curved hood was far better than the squared off Kubota. But I didn't see much real difference between it and Deere's. The Deere LOOKED squared off, but actually had a lot of slope. ( I actually printed out pictures of both, at the same size and overlaid them, from the operators position, the difference was negligible...) But then, I would have had to go to a Class III boomer, compared to the Mid Chassis Deere...
I REALLY like the new loader's grease points!
   / 4020 Series Specs #8
Thanks for the info....I wonder what one will cost ?????????? /forums/images/graemlins/confused.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
   / 4020 Series Specs #9
They'll sure be more than I would need or could afford, but some mighty good looking machines !
   / 4020 Series Specs #10
The wrap around lights look nice, but they sure disappear with the loader in place.... /forums/images/graemlins/shocked.gif
2015 Nissan Sentra Sedan (A53117)
2015 Nissan Sentra...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
1994 Trailmobile 51 ft. Dry Van Trailer (A53117)
1994 Trailmobile...
377811 (A48836)
377811 (A48836)
1273 (A50490)
1273 (A50490)
