4010 and Wallenstein 3pth log spliter
   / 4010 and Wallenstein 3pth log spliter #1
friedlake
Ontario, Canada
2010 JD 3520 Cab / Bobcat E35 Cab excavator
Looking at purchasing a 3pth log splitter for my 4010. I split about 14 bush cord of hardwood/year. My question is will the low gpm of the 4010 run the splitter effeciently or not. Also adding on a power beyond kit. Will this improve its operating ability? I was quoted 350 (cdn) for the PB installed and 800 for the wallenstein splitter. The gpm ( 5.5gpm ) of the tractor is quite alot less than most stand alone splitters( 12-20gpm ) but the Hp and torque is greater on the tractor. not to mention the cost is alot less for the 3pth splitter! I would appreciate your opinions!! i found lots of disscussions but not any input from owners of small cuts who have actually used a 3pt splitter. ( Maybe my first clue of its effectivness or uselessness???)
Thanks in advance!
Jamie /forums/images/graemlins/confused.gif
   / 4010 and Wallenstein 3pth log spliter #2
Jamie,
</font><font color="blue" class="small">( found lots of disscussions but not any input from owners of small cuts who have actually used a 3pt splitter. )</font>
I bought a three point splitter from Northern Tool about a month ago. To date I have split a little less than two cords (4'x4'x8' - not sure what a "bush cord" is).
Running it on a John Deere 4300 using the power beyond I can extend the cylinder (4x24) fully in 9 seconds at rated speed (2700). If I run wide open I can reduce the stroke time to 8 seconds, but 9 seconds is fast enough for what I have to do. I've never bothered to time a full cycle since I'm usually getting another log or moving the log back for another pass while the cylinder is returning. My tractor puts out about 9 gpm.
At 5.5 gpm, I would expect the ram travel to be significantly slower - probably 14-15 seconds to fully extend the ram. The return is ordinarily a little faster since less oil is required due to the displacement of the cylinder rod.
I would find that slow pace a bit tedious and I suspect that you might be happier with a faster setup - probably a self contained unit.
Thanks Jim! Thats the kind of info I was looking for! I suspect a stand alone splitter will be the way to go!
Jamie
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
