400x vs 400cx specs question
/ 400x vs 400cx specs question #1
bam747
Palmer Divide in El Paso County, Colorado
John Deere 4720 (2007)
A couple weekends ago I was at a Deere dealership and found a new "Compact Tractor Implements and Accessories" brochure produced by Deere. In that brochure they had a table listing their various loader specification.
Here's what has me baffled... :confused:
Lift capacity at pivot pin (max height): 400x = 2341 lbs, 400cx = 2378 lbs.
Lift capacity at 500mm ahead of pivot pin (max height): 400x = 1716 lbs, 400cx = 2565 lbs.
Those numbers say the 400cx lifts 849(!) more pounds in the "real world" 500mm ahead spec than the 400x! :eek:
Lift capacity at pivot pin (59" height): 400x = 2695 lbs, 400cx = 2691 lbs
Lift capacity at 500mm ahead of pivot pin (59" height): 400x = 2149 lbs, 400cx = 2633 lbs.
Again, the 400cx beats the 400x by 484(!) pounds in that 500mm ahead spec.
I know the 400cx is a mechanically self leveling FEL, but I don't understand how that would make it have significantly HIGHER capacities at 500mm AHEAD of the pivot.
Any ideas why this is happening with the 400cx? Is it some kind of geometry thing with the way the MSL arms work?
/ 400x vs 400cx specs question #2
If the 400 series are like the 300 series the CX is the more potent version. What I don't see is how the 400CX can have a greater lift capacity ahead of the pivot than it does at the pivot. Something doesn't make sense. Are you sure of your figures??
Well, all I can say is I'm sure I read the figures from the Deere brochure properly. I did a double take or two when I first saw them. I tripple checked that I wrote down the correct numbers from the brochure when I created my post.
/ 400x vs 400cx specs question #5
has any body tried to get the extra parts that a cx uses and put them on the regular 400?
i told my dealer about that and he said it wouldnt work but they sure look like it to me with them sitting side by side
/ 400x vs 400cx specs question #7
Anyone get an explanation for the 400x vs 400cx magical lift capacity increase yet? I agree, it doesn't make sense.
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
(4) New Caterpillar Skidsteer Loader Tires (A66408)
(4) New...
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
DR All Terrain Field and Brush Mower (A65579)
DR All Terrain...
