400x loader
/ 400x loader #1
trippert
southeast Oklahoma
John Deere 4320
Has anyone had problems with the quick attach brackets on the 400x loader? I have broken one on each side where the pin on the bucket goes through bracket. That part of the bracket is about 1/4" cast. This is my first experience with a part breaking on a JD loader, I've used others the same way I use this one and never had a problem. Just wondering if anybody has used one and had similar results.
T
/ 400x loader #2
Welcome to the forum.
Been around a lot of Deere tractors and loaders, but this one escapes my recollections. What tractor is it on?
A pic of the damaged part area would help too.
Your bio please - thanks.
/ 400x loader #3
I have a 400x on my 4720
I Have had no problems, however I've never even taken the bucket off yet. Only 80ish hours on the set right now.
I don't think there are too many 400x loaders out there just yet.
tom
/ 400x loader
Here are some photos of the part and its mate. I have looked at other JD loader hookups and they are all plate, welded steel. This is a cast part.
/ 400x loader
More of the part
/ 400x loader #8
AT LEAST I'M NOT THE ONLY ONE TO EXPERANCE THIS,HAD 4.5 HRS. ON MY BRAND NEW 4520 WITH A 4 IN 1 BUCKET,SNAGGED A SMALL ELM STUMP BROKE THE BUCKET CLEAN OFF THE LOADER.CALLED THE DEALER,SAID IT'S THE FIRST TIME THEY HAD HEARD OF SUCH,ASKED THEM TO COME SEE IT,HAVEN'T HEARD FORM THEM SINCE.IN THE MEAN TIME I WELDED LOADER BRACKETS.NEED TO MAKE SURE I FOLLOW UP WITH DEALER.
/ 400x loader #9
</font><font color="blue" class="small">( Here are some photos of the part and its mate. I have looked at other JD loader hookups and they are all plate, welded steel. This is a cast part. )</font>
On my 4520 with the 400X FEL, the part appears to be a forging rather than a casting. Sand castings usually have a 'grainy' appearance/feel, whereas forgings are somewhat smoother. And, as you undoubtedly know, forgings are almost always stronger than rolled plate steel. But, appearances can be deceiving, especially after having been painted with the John Deere green.
/ 400x loader
If you break this part it should be covered by warranty. I doubt if it will be covered after welding but it is worth a try. My dealer told me that if enough of these break that JD sometimes steps back and looks at the design possibly changing it to reduce breakdowns. BUT you have to let your dealer and/or JD know there is a problem. Also, my dealer said as long as it is covered under warranty to keep bringing the two halves in and they would replace them- after it's off warranty, then look at another fix, if JD has not changed the design.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2005 (INOPERABLE) FREIGHTLINER COLUMBIA 120 (A67714)
2005 (INOPERABLE)...
PORTA POTTY (A67714)
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
