400x Cylinder repair help
   / 400x Cylinder repair help #1
kbhawaii
Holualoa, Hi
JD 4520
I'm trying to install a new seal kit for my 400x bucket cylinder on my JD 4520 but I can't remove the shaft. I've removed the top snap ring but when I pull on the rod it seems to have another ring that is catching on the inside grove near the top of the cylinder. I can move the rod up and down but when pulling out, it's catching. Thought it may need more pull force so I hooked it up to my truck to pull apart but was not successful. Suggestions???
   / 400x Cylinder repair help #2
In your new seal kit is a orange plastic part push the end sleeve into the housing and see the grove and this plastic part fits into the groove. then quickly pull the shaft out of the cyl.
and use again when reinstalling the new seals it works . just make sure the part is fitting good in the grove.
Also in the Hydraulic forum read thru J.J.'s answers several to this problem.
And Welcome to TBN
ken
Thanks Ken, it's nice living in "paradise" but everything has to be flown in, the local JD dealer doesn't carry much inventory. I'm waiting on delivery of the kit so I'll stop pounding and pulling. Doug
DESK (A53843)
DESK (A53843)
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2006 Kubota L3130 (A50123)
2006 Kubota L3130...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2022 Ford F-550 4x4 Ext. Cab Flatbed Truck (A51691)
2022 Ford F-550...
2025 CFG Industrial MX12RX (A50123)
2025 CFG...
