400x Cylinder repair help
   / 400x Cylinder repair help #1
kbhawaii
Holualoa, Hi
JD 4520
I'm trying to install a new seal kit for my 400x bucket cylinder on my JD 4520 but I can't remove the shaft. I've removed the top snap ring but when I pull on the rod it seems to have another ring that is catching on the inside grove near the top of the cylinder. I can move the rod up and down but when pulling out, it's catching. Thought it may need more pull force so I hooked it up to my truck to pull apart but was not successful. Suggestions???
   / 400x Cylinder repair help #2
In your new seal kit is a orange plastic part push the end sleeve into the housing and see the grove and this plastic part fits into the groove. then quickly pull the shaft out of the cyl.
and use again when reinstalling the new seals it works . just make sure the part is fitting good in the grove.
Also in the Hydraulic forum read thru J.J.'s answers several to this problem.
And Welcome to TBN
ken
Thanks Ken, it's nice living in "paradise" but everything has to be flown in, the local JD dealer doesn't carry much inventory. I'm waiting on delivery of the kit so I'll stop pounding and pulling. Doug
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A53426)
2020 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 Kia Sportage LX SUV (A53117)
2015 Kia Sportage...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
