Comparison 4000 twenty series
/ 4000 twenty series #1
PioneerMan
Is the only difference between 4120 through 4720 horsepower and a few options? I like the ePTO on the higher hp models, but if I got the lesser hp models wouldn't it be basically the same, just working at full rpms?
/ 4000 twenty series #2
The difference is fuel economy, and noise. If you need all the HP the tractor can give, then e-pto won't buy you much. For many jobs the degraded HP is enough.
/ 4000 twenty series #3
PTO horsepower requirements should dictate your purchase - buy according to what implements you will run. If all you are doing is loader work, they all weigh the same and the 4120 I had would run out of traction long before horsepower.
